Old 25-03-2018   #1
Map sensor
Not had my 2014 1.2 Panda very long and have just had map sensor replaced but same problem occurred yesterday. Only collected it from garage Saturday morning! Warning comes up on dash and Check Engine. Drove home in limp mode. Anyone know of a solution for this problem. Canít believe my bad luck!
AEC123 is offline Reply With Quote Quote
Old 26-03-2018   #2
2017 Panda City Cross
murphyv310's Avatar
murphyv310 has donated!
murphyv310 is an honorary friend of the forum :)
Re: Map sensor
Hi
Sorry to hear of your woes. I'd assume then the fault was misdiagnosed? I'd return to the garage and tell them the part fitted has not cured the issue. Insist that you have a printout of the fault codes and that you are not paying any thing else until the fault is fixed and that the MAP sensor was quite obviously not the issue. Remind them of your rights and if necessary you'll speak to trading standards.
Incidentally has the car been properly and regularly serviced?
Cheers Trevor
murphyv310 is offline Reply With Quote Quote
(T) Manifold Pressure Sensor (MAP sensor) repeated failures Powellj3 Panda (2012+) 3 01-07-2017 15:36
What cars use the same MAP Sensor, Coolant Sensor and TDC Sensors as 1997 1.1 Punto ? d1ckyboy Lets Talk FIAT 6 26-10-2011 23:45
(T) HT leads, MAP sensor, Lamda sensor & dizzy cap ashar786 Uno 1 30-06-2008 01:37
(T) punto 1.3 multijet MAP sensor & IAT sensor spence Punto (Mk2/2b) 0 14-06-2008 09:25
(T) Oil on MAP Sensor & Sensor wires scorched?! DaveX Stilo 6 09-09-2006 08:17
