A generation to me is a brand new platform, a Mk is any significant change. Between 141 and 141a was more than cosmetic, hence why everyone who knows anything about classic Pandas distinguishes them as Mk1 and Mk2.
In that case then, why isn't the facelift model mk2 Punto known as the mk3 instead of the mk2b?
Not to mention the introduction of the 1.3 MultiJet.Because there weren't significant changes. Everything mechanical was basically identical aside from the switch to the 1.4 in the Sporting model. It was pretty much just a facelift.
I must admit, what confuses me is when people call the facelift version of cars a new mk: for example, people refer to the late 1997 Mondeo as the mk2, whereas I still consider it to be a mk1, as it was just a facelift.
Would you still buy a 4th Generation Panda, if FIAT would put the New GSE-Firefly engines in the present 3th Generation Panda. ??
I would say no. First, I love the twinair and don't feel the need for a different engine so changing just for that would be pointless.
Second, if I look at the new Ford Fiesta and what they've done with the interior, the big touchscreen with a good user interface and esspecialy the B&O entertainment system it's clear to me that things have to move on in this departement to convince me to get a new car.
But if the Panda I own now would last forever with only service and some new tires it would be fine by me
At this point I can say my Panda does, just service and tires.
After the UNI-Air module replacement it's performing flawless.
If the stories are to believed, will the next gen Panda get 2 Mild-Hybrid versions.
Both GSE-Firefly, 1 will be the 999cc 3 cylinder and the other the 1332cc 4 cylinder.
The 3 cylinder would be ± 71 hp + Mild-Hybrid and the 4 cylinder would be ± 101 hp + Mild-Hybrid.
The mild-hybrid will give a torque boost when needed.
