FIAT Auto Specialist Team
Old 06-03-2018   #16
Re: Where to buy TA oil from
Does just fine in my TA..fancy labels and bottles is smoke and mirrors to me..Click image for larger version
Thanks PhilTwo Pot Panda LOUNGE
Phils panda is offline Reply With Quote Quote
Old 06-03-2018   #17
2017 Panda City Cross
murphyv310's Avatar
murphyv310 has donated!
murphyv310 is an honorary friend of the forum :)
Quote Originally Posted by Phils panda View Post
Does just fine in my TA..fancy labels and bottles is smoke and mirrors to me..Attachment 188876
Attachment 188877
Phil.
I'm certain that is the wrong spec for the TA. Your photo shows a C3 10w 40 that is for the 1.2 Fire engine which specifies a low saps oil. The TA is a C2 I believe. Plus it should be 0w 30.
Likes Peter Pick-Up liked this post
Cheers Trevor
murphyv310 is offline Reply With Quote Quote
Old 06-03-2018   #18
Hi trev its 5w40 full syn c3 ..works fine..
Old 06-03-2018   #19
Yes trev..but some are differant mines on a 61 plate so runs the older spec oil.. this type of thread has been for ever now...
Thanks murphyv310 thanked for this post
Old 06-03-2018   #20
murphyv310's Avatar
You are right Phil.
Only the lower NA TA specifies a C2 oil. 5W-40 should be OK but it was changed to 0w-30 I believe on later engines.
Thanks Mercky, MuddyPaws thanked for this post
Likes Phils panda liked this post
Cheers Trevor
Old 06-03-2018   #21
A pic from hand book..Click image for larger version
Likes murphyv310 liked this post
Old 06-03-2018   #22
Moderator
A pic from hand book..Attachment 188881
Not all TA's will have this specification of oil; it was changed on later models and, one would hope, so was the handbook.
NEVER rely on information contained in a handbook for someone else's car. Use the information that's contained in your own handbook. Manufacturers can, and do, change specifications at any time during a car's production run, and the handbook for your specific car should reflect this.
"Just 'cos you're not paranoid, doesn't mean they're not out to get you"
jrkitching is offline Reply With Quote Quote
Old 06-03-2018   #23
Moderator
Peter Pick-Up has donated!
Russia
Not always.
We bought a brandnew 2016 Euro 6 Alfa Giulietta MultiAir two years ago, came with the wrong Euro 5 handbook...
Anyway, with the MultiAir engines the Euro 5 ( until about 2014) use 5W40 C3 oil, the Euro 6 versions after 2014 use 0W30 C2 oil.
I assume it's the same for the TwinAir engines.
Likes MuddyPaws liked this post
Peter Pick-Up is offline Reply With Quote Quote
Old 06-03-2018   #24
murphyv310's Avatar
Page 222 on my 2014 dated handbook.
And a contradiction in the Euro 6 supplement
ID:	188892   Click image for larger version
Thanks jrkitching thanked for this post
Cheers Trevor
Old 07-03-2018   #25
Netherlands
Would it be wrong to use 0W30 in an older '12 TA?
gr J
"Look for the ridiculous in everything and you will find it". - Jules Renard
A3jeroen is offline Reply With Quote Quote
Old 07-03-2018   #26
0w 30 was in my TA 4x4 from 10k miles if not before. Very quiet, zero usage and no issues with any funny noises. Worth paying extra even for early cars.
Al D is offline Reply With Quote Quote
Old 07-03-2018   #27
Moderator
Russia
Quote Originally Posted by A3jeroen View Post
gr J
In almost all cases I would say yes.
I changed viscosities, quality, and so on, on lots of cars and bikes without problems at all.
But with the MultiAir and TwinAir units I wouldn't risk anything.
The function of those units depends heavily on oil ( viscosity and quality).
A lot of those units have failed due to wrong oil, so I would stick to the handbook ....!!
I'm a Castrol guy all my life, but since we own an Euro 6 Alfa Giulietta with the 1,4 MultiAir Fiat engine, I use Petronas ( or Selenia...) cause Castol doesn't make a 0W30 C2 synthetic, infortunatley..
Old 07-03-2018   #28
murphyv310's Avatar
Quote Originally Posted by Peter Pick-Up View Post
In almost all cases I would say no.
Surely if there are no changes to the construction and tolerances in the engine and the manufacturers change the spec of the oil then there won't be an issue in the older engines. I'm sure Fiat service use the new spec in older TA engines, I've read it on here before.
Cheers Trevor
Old 07-03-2018   #29
Moderator
Quote Originally Posted by murphyv310 View Post
Do we know that? I've yet to see any authoritative statement on that subject, either way.
Old 07-03-2018   #30
Moderator
Russia
It's the other way around, many of them use the old specs oil in the new engines....!!
They have plenty of the old specs oil in store, and not that many new Euro 6 engines around, it's not economical to have the new specs oil in bulk, I'm afraid...
(G) What engine oil to buy? MoS110 Bravo 4 11-05-2017 10:15
Where to buy Engine Oil ? arorat Leisure Lounge 10 29-01-2013 20:46
(G) GP 1.3 90 HP M-Jet Which Oil to buy carattano Grande Punto 3 20-11-2011 09:30
(T) Oil needs topping up - What should I buy? JD82 Panda 52 15-08-2010 22:06
(T) Which oil to buy oktopod Punto (Mk2/2b) 23 25-03-2008 19:17
