Hello all,
I am replacing the clutch and release bearing on my 2012 1.2 panda tomorrow! It has done 46,000 miles which is low but it is all town driving, and I am 6'2 with big feet, and probably don't treat it with the kindest manner. Love the car though!
It has been whining for a while now and then, juddering and slipping here and there, with a burned clutch smell. It banged real loud the other day as I was pulling out into traffic, the car lurched forwards and the clutch pedal jumped up, almost like something was trapped between the clutch plates.
There has been a rattly loose broken sound coming from the clutch housing area when being driven, ever since the bang. It still works and the car drives, but it is certainly not right. Pressing the clutch stops the noise.
I am assuming it is the clutch that has died in some way, possibly a spring finger snapped off, or the release bearing broken, or friction material broken off, or similar.
The new clutch assembly with bearing and clutch alignment tool cost me £93.00. Mr. Clutch quoted £350 to do the job, and Fiat quoted £780!!! No way. It is simple enough to do, just time-consuming.
Does anyone know if there's anything particular to watch out for on these new pandas like a hidden split pin or circlips, or is the job pretty standard as far as FWD cars go? I.e. Wheels / driveshafts out, unbolt everything and separate the Gbox.
If anyone is interested, I can report back here after the job with some pictures.
Andy C
Andy C
