Old 27-01-2018   #1
Lights won't turn off!
Fiat panda MK4 1.3 multi jet diesel.
Hey guys
So a while a go I realized that I couldn't turn off my headlights. I've checked the fuse relay box, it's bone dry, I've checked all the fuses and they all seem okay.
I think I've narrowed it down to the actual stalk, the switch doesn't work. I've seen something similar on another thread for a different fiat where the guy found out that it was a wire that had broke within the stalk.
Now how do I get to the wiring of the stalk?
I'm assuming at this point I need to remove the steering wheel, problem is I can't find any info specific to a MK4 panda.
I am keen to do this fix myself as I'm about to pay out to get the EGR valve replaced as well as a few other things so I'm fairly skint for a while.
Cheers guys
PaulyMcPaulFace is offline Reply With Quote Quote
Old 27-01-2018   #2
varesecrazy has donated!
Re: Lights won't turn off!
Only advice I can give:disconnect battery overnight.
That will disable any airbag power.
Then it should be a simple plastic trim battle....
Old 27-01-2018   #3
Let the battle commence....
I'll post an update if I get it done, chances are I'll fail, and just have to put up with changing the bulbs more often than I otherwise would.
Old 01-02-2018   #4
Turkey
While we don't have a proper manual for the 312 Panda yet, this issue is somewhat well documented here in the Forum. Folks in warranty get a replacement stalk from Fiat, others haven't had much luck since replacement stalks may (or may not, my memory is fuzzy on this) require an introduction to the vehicle body computer or ECU, which would require compatible ECUscan software and hardware. Then again, since I don't think anyone has undertaken the task of looking at what actually is the issue, you might be a pioneer in the field and figure out what's going on.
Likes PaulyMcPaulFace liked this post
oyumurtaci is offline Reply With Quote Quote
Old 09-02-2018   #5
Well at the moment I'm assuming it's a simple broken wire in the stalk. If it does come to replacing the entire unit I would assume so let me s it's the same model it should just plug in and work. I haven't found any replacement stalks yet, just the unit itself that will have both stalks.
So far not so great, I'm unsure on how to remove the steering wheel, well paranoid anyway that I may break it and create an expensive problem. I'm hoping to have time to have another crack at it this weekend.
Pioneer you say....I like that!
Old 09-02-2018   #6
Quote Originally Posted by oyumurtaci View Post
Also, on another note, I don't suppose you know how long it takes to replace an EGR valve? I don't want to get bent over when I take it in to a garage if you know what I mean. Plus I'm somewhat poor.
Old 09-02-2018   #7
No Fiat now unfortunately
murphyv310 has donated!
Hi.
If my 2001 Doblo is anything to go by then I'd say the stalk (switch) could well be the issue.
The Doblo had a an intermittent wiper operation that I inherited from the previous owner (Fido, on here)
Occasionally, the wipers would run all the time others they didn't come on.
After an awful lot of searching the stalk was blamed. It was expensive, I was skint and there were none in the scrappy.
I deduced that the contacts were only passing a few milliamps and would either get tarnished or any grease could get conductive if contaminated with debris or even dampness. So sprayed contact cleaner into the area that I thought contained the contacts, it was rather hit and miss as I didn't dismantle the switch but after a fair amount of the cleaner the problem was cured. I had no issues at all after wards.
I'm not saying the same problem is the one you have but it may be an idea to give it a try, so long as you can get to the contacts or even in a join in the moulding ad you aim in the right direction then you may be lucky.
A spare switch could be dismantled so we could see what is actually inside. I also cant see why one of these switches should need to be coded in??
Cheers Trevor
2M0GZQ
murphyv310 is offline Reply With Quote Quote
Old 09-02-2018   #8
Nice one, cheers for that. I'll try that first.
Old 10-02-2018   #9
Turkey
Haven't attempted that yet, but considering how ubiquitous the 1.3 mj is, I'd imagine there are plenty of guides out there from a different model.
Old 10-02-2018   #10
It depends on the technology used in the switch. It may be different to my 2001 Doblo now. It is possible they use optocouplers, or a rotary encoder now, they do still get gunged up like in hi fi wolume controls.
Cheers Trevor
2M0GZQ
Old 21-02-2018   #11
Hey they recalled the panda 2012 to programme the body computer for this fault, and if the lights stayed illuminated then if the production date of the switch unit behind the steering wheel was before a certain date then they would change this also.
Thanks PaulyMcPaulFace thanked for this post
Likes PaulyMcPaulFace, varesecrazy liked this post
wigan_muncher is offline Reply With Quote Quote
Old 21-02-2018   #12
Cardiff / Oxford
Old 22-02-2018   #13
Quote Originally Posted by wigan_muncher View Post
Ooooh, interesting, I shall contact the desira dealership I bought it from, thanks!
Old 22-02-2018   #14
Turkey
If by any chance anyone can get their hands on the service memo for this recall, or the actual recall notice, we could probably use it for all future queries on this issue (though dealers are usually very protective of the internal memos for these recall notices).
Thanks murphyv310 thanked for this post
Old 12-04-2020   #15
Hello, ive a 2012 panda project thay has this issue and accorsing to vosa site, im not eligible for a free fix! Theres plenty of folk with this issue and not much helpful advice beyond battery disconnect and hope. Ive been doing a bit of diging, heres what ive found if someone wants to add suggestions to try and bottom this issue out. Test 1, power up car with steering wheel off and disconnect lighting control makes no difference. So the bcu is getting a ground signal from somewhere other than switch.
1, switch itself. Opening this up the wiring is very fine and connects to a small circuit board. 2 wire, simple negative return system ( lights on grounda and sends earth connection to body control unit). Using multimeter, switch and wiring appear fine.
2, body control unit. Under passenger glovebox on uk models. Removed and split this. There no guide to show what the function of the board is. Various micro relays. Having cut away the plastic covers the relay mechanisim is exposed. Wiring the bare board back to the car and tapping eavh relay mechanisim with a fine screwdriver activates various functions such as windows up and down, locking etc. Whilst there are relays that operate with the conteol stalks on the steering wheel, none if them affect lights. The board on the panda is dual layered. Any idea of desoldering replacement micro relays can only be a job for someone even more brave than me.
3, fuse box in engine bay. So stripped this out also to try and identify relay that operates lights. This would allow relay swap to rule out faulty relay. There is no relay and 20amp fuse that controls lights also controls all the power in the car.
Summary so far. The body control unit may well be faulty and can be swapped for scrappy one at the loss of locking as the car keys coded to bcu. Other option is to ignore and leave lights on fulltime controlled only by key. The lighting control has clearly been upgraded from last model. Thinking its computer controlled and will need to source full diagnostic software to test.
If anyone can add usefull suggestions to investigate next im happy to oblige!!
Bigrinks is offline Reply With Quote Quote
(T) Front fog lights won't turn off (5D Stilo -06) JariR Stilo 0 05-01-2016 07:44
(T) Lights won't turn off ? Scudo19d Scudo 2 12-01-2012 18:50
(T) Rear interior lights won't turn off. Hellcat Bravo 3 19-10-2010 13:35
(T) My LED side lights won't turn off! djwazza Punto (Mk2/2b) 3 03-12-2007 12:11
(G) Brake lights won't turn off!! Torq Ducato 4 13-12-2006 20:45
