I need to get at the front DRL lights. I assume it is via the lower spot lamp aperture. How does this open up/be removed. I can lever it from the inner edge but does not "pop out". Before I break summat...any ideas?
They're actually easy to get to from above via the open bonnet, but there's also an access panel in the front wheel-arches that are directly behind the DRL's and Fog Lights. All very easy, provided you clean up the Phillips-headed securing screws properly first so as not to bugger up the head. They sit in one of the dirtiest places on the planet, after all....
