Old 28-12-2017   #1
Spain
DRL's
I find it really annoying with cars that have front only DRL's. Mainly because the driver's forget to turn their lights on in poor visibility.
Can both front and rear lights be put on as DRL's?
bimmer is offline Reply With Quote Quote
Old 30-12-2017   #2
Turkey
Re: DRL's
I'm sure there are some hacks to the wiring that might allow for it, but odds are the CANBUS system would throw a fit, thus requiring fitting LEDs and proper resistance to compensate for it all.
I'm with you on the lights though, I really wish the bottom part of the tail lights were always on.
Likes The Panda Nut liked this post
oyumurtaci is offline Reply With Quote Quote
Old 31-12-2017   #3
JerryR has donated!
Re: DRL's
Totally agree, the number of vehicles driving around in poor weather conditions with just their drl son is appalling. I’m sure that drivers think that they are just more powerful side lights that are showing both to the front and to the rear. My sister in law did until I informed her.
JerryR is offline Reply With Quote Quote
Old 31-12-2017   #4
Netherlands
Re: DRL's
Yeah the DRL light situation is pretty stupid in my eyes. Loads of stupid rules for everything but these are alowed in the way they work now. When driving in to misty situations and fog almost nobody remembers to turn their light on.
My light are always on, can't forget them either because the clever people at Fiat ket them turn off when you turn of the car.
TheR is offline Reply With Quote Quote
Old 31-12-2017   #5
Re: DRL's
Are the DRL's as standard LED bulbs? Are they reliable?
Max.
Dervdrain is offline Reply With Quote Quote
Old 31-12-2017   #6
Netherlands
Re: DRL's
Quote Originally Posted by Dervdrain View Post
No just ordinary old fashioned glow bulbs.
Old 31-12-2017   #7
Re: DRL's
Ahh, thanks. Do they blow all the time then like other filament DRL's?
Guessing there is a forum favourite LED substitute?
Max.
Old 31-12-2017   #8
Moderator
g8rpi's Avatar
g8rpi has donated!
Re: DRL's
No legal LED replacements for filament lamps I'm afraid. The "no lights" problem is a driver education issue, not regulations or car design. They do not not put rear lights on with DRL's as it reduces the perception of brake lights during the day.
Robert G8RPI.
Likes murphyv310, oyumurtaci, Peter Pick-Up liked this post
g8rpi is offline Reply With Quote Quote
Old 31-12-2017   #9
Re: DRL's
Mine's 4 years old this week. Used practically every day. During the week, an hour-long commute each way. No bulbs blown yet... (except the headlights, where I've had to replace both sides)
Likes TheR liked this post
2018 Panda 4x4 MJ :: North Herts :: Remember, if you find a post helpful, press the smiley face 'thanks' button below
Herts Hillhopper is offline Reply With Quote Quote
Old 01-01-2018   #10
Goudrons has donated!
Re: DRL's
Theoretically, it's possible and wouldn't be too difficult.
The DRL's are always on if the ignition is on, you'd just need to hard wire the rear lights up to a switched live power source, like you would with say a Dashcam.
What effect this would have on the system that monitors the bulbs, I'm not sure.
With the lights switched on, you'll have two lives, live to the rears, the headlight circuit and the hardwire circuit.
I'm not an electrician, but I seem to think the bulbs will only pull the power they need, so it wouldn't matter if they have two feeds, but switching on the original circuit might cause a spike and blow the bulbs.
You can't just cut the original rear light feeds so the light switch only operates the headlamps as that would no doubt cause warning issues with an open rear circuit, perhaps the cut circuit could be looped together so the system doesn't detect an open circuit?
Another option would be to just hardwire in via a switched live some small LED bulbs inside the actual rear light clusters.
Drill the right size hole through the cluster backs and screw/hotglue them into the backing in the correct section.
Something like those LED eagle eye lights.
Goudrons is offline Reply With Quote Quote
Old 01-01-2018   #11
Spain
Re: DRL's
Not strictly true G8RPI, many manufacturers have front and rear DRL's. I believe 4 is better than 2 front only.
Old 01-01-2018   #12
Spain
Re: DRL's
Goudrons: I'm no stranger to "lights on" technology as my own car is a VOLVO with "perma lights". To get a feed to the rear would be a job not worth undertaking, I'll just put the headlight switch on all the time.
Old 01-01-2018   #13
Moderator
g8rpi's Avatar
g8rpi has donated!
Re: DRL's
Quote Originally Posted by bimmer View Post
The current definition of DRL is front only, otherwise they are position lights. Some older requirements may have had rear as well. Guidance here:
https://www.gov.uk/government/public...running-lights
includes
"DRL activate automatically when the engine is started and remain on unless the headlamps are switched on. They may however remain off in some low speed and stationary situations. In general all other lights should remain off when the DRL are on but for a limited period some vehicles may be available which automatically activate the rear position lamps at the same time as the DRL."
Which allows for these, but all new designs should be front only.
Robert G8RPI.
Old 02-01-2018   #14
2017 Panda City Cross
murphyv310's Avatar
murphyv310 has donated!
murphyv310 is an honorary friend of the forum :)
Re: DRL's
Hi.
Robert is correct with his description. The idea of DRL is pedestrians, cyclists and other oncoming vehicles are more aware of the vehicle with DRL. There has been many tests and data from all over the EU and it is proved that it has reduced accidents.
Drivers should be aware that like over nearly 100 years lights are still needed to see, when did that change that we can't?
There is no need to have rear lights Illuminated in daylight but again in fog why do some idiots think they are safe with just DRL? Its beggars belief.
Why don't some drivers understand the D means Daylight?
Cheers Trevor
murphyv310 is offline Reply With Quote Quote
Old 02-01-2018   #15
Burkina Faso (Upper Volta)
Re: DRL's
with regards these lights
they are quite bright on the front plus the dash is lit too
so its very easy to drive your car in urban ie 30mph areas with good street lighting and not realise your taillights are not lit ive done it
secondly how do i put my parking lights on when i go to see a certain relative who lives on an unlit 40mph street
s and b is offline Reply With Quote Quote
(T) Drl irelach1984 500L 1 13-03-2017 09:33
(T) DRL again Mick F 500 48 23-12-2016 17:26
(G) Drl's manxman020 500L 12 19-06-2015 15:48
(S) My DRL'S xlTomm Grande Punto 26 09-04-2013 12:00
(T) DRL's muttleysdad 500 2 28-09-2008 01:48
