Car has developed a fault over the last few days which is gradually getting worse, it started as follows:
From cold start would start straight away the revs would drop below 500rpm the after a few seconds would go to just over 1000rpm then settle at 800 ish.
Now it starts and runs for 2 seconds bogs down and stall and brings up a message saying start stop not avialable (probably because there is a fault somewhere)
Once its been running for a few minutes it then runs normal again.
Also ifs its started left running for a few minutes then stopped the next time it starts fine.
Has plenty of diesel and battery is in a good state of charge.
Car is a 2014 1.3 multijet 4x4 30k miles.
My first thoughts would be glowplugs, but it starts straight away with no smoke or lift pump, if it has one?
Any help would be greatly appreciated as dealership service department is closed now until monday
