FIAT Auto Specialist Team
Old 30-09-2017   #1
FIAT Panda clutch switch Euro6
Here's a guide to the Murphy-modification used to get rid of the annoying rev-fluffing when you set off in the Euro6 Panda 1.2.
It's a sensible choice for those who like to control their launches (see image for numbering):
Before doing anything, have a light source, the drivers seat fully back and preferably tiny hands and no back problems. No tools required for the switch part.
1. Disconnect the switch. Doing so means you'll get the warning/light, even when you reconnect so budget for a cheap code resetter.
2. Move the weedy lever toward the front of the car and..
3... then pull it to the right. This is what holds the switch in place. You can then pull it away at the joint and it'll move around loosely.
4. Push the yellow 'cage' upwards which then allows you to slip the switch out from the clutch lever.
5. Once the switch is out, stick it on the left side of the steering column and move the wire to reconnect. Perhaps stick it to the back plastic with gaffer tape.
6. Pull off the right-hand ODB cover and plug in your device - reset the warning
7. Stand back, light your pipe and admire your handiwork.
Thanks Murphy.
Thanks murphyv310 thanked for this post
Likes t0neloc, murphyv310 liked this post
AB100 is offline Reply With Quote Quote
Old 01-10-2017   #2
2017 Panda City Cross
murphyv310's Avatar
murphyv310 has donated!
murphyv310 is an honorary friend of the forum :)
Re: FIAT Panda clutch switch Euro6
Great write up and a well worth mod to do.
The MIL light doesn't come on if you are able to do the job and position the sensor/switch lever in the rest or equivalent of the clutch pedal up position. The little lever has a light spring and the lever should stay that way unless it's pressed, all should be fine.
Mine is neatly tucked behind the plastic footwell cowling.
Cheers Trevor
murphyv310 is offline Reply With Quote Quote
Old 20-12-2017   #3
Italy
I'm interested in this change, but I would not do damage, someone did a video ??
Davidoff46 is offline Reply With Quote Quote
Old 20-12-2017   #4
Quote Originally Posted by murphyv310 View Post
There's no video but the photo pretty much shows all. Bear in mind this was on a UK right-hand-drive car.
Not sure how the Left-hand-drive looks but would expect similar.
Old 20-12-2017   #5
murphyv310's Avatar
I didn't take any pictures. The job is awkward with arthritis and even worse using a camera. To be fair its really self explanatory once looking at it. The effort is well worth it.
Cheers Trevor
Old 21-12-2017   #6
Italy
thank you guys ,one more question, what do you mean by "rev-fluffing" ??
means that it drowns at the start??
Old 21-12-2017   #7
murphyv310's Avatar
Hi.
I think that what happens is when you take away especially if you are not a new driver you just expect the engine revs to just rise gradually as you press the throttle and bring up the clutch. Not so with the clutch switch in place, as soon as you bring up the clutch pedal the revs rise by 200rpm but a little throttle and the revs rise disproportionately up to 2000 rpm at times, then it can bog down too at times. You are left wondering what it will do at the next standing start. Perhaps if all new cars are like this then new drivers can adapt easier than us old codgers, to be fair though its not the way any car should drive.
Cheers Trevor
Old 21-12-2017   #8
Italy
I think my panda is different from yours...
Old 21-12-2017   #9
Became old and sensible
MrDerv's Avatar
MrDerv has donated!
2 things to bare in mind...
1, This will affect your Stop/Start
2, You'll have to restart the engine by key if you stall, rather than just pushing in the clutch.
Current Garage
Mine: 2013 VW Passat Sport BlueMotion Tech 2.0 TDI Stage 2 Mapped
Hers: 2007 Renault Megane 1.6 VVT Auto Dynamique
MrDerv is offline Reply With Quote Quote
Old 21-12-2017   #10
murphyv310's Avatar
Mine doesn't have stop start. Does any 1.2 Panda have it?
Cheers Trevor
Old 21-12-2017   #11
Quote Originally Posted by Davidoff46 View Post
Image is too small to make out but I am not seeing the top of the clutch pedal lever like in the diagram I have shown.
It will indeed affect your Stop-Start presumably, though I have that disabled anyway.
Old 21-12-2017   #12
Italy
precisely where is this switch ??
Old 21-12-2017   #13
It's just below the Clutch level/pedal inside the car. On my image you can see the brake pedal piston in the foreground.
You will need to get your head on the floor and use a torch. Follow the clutch pedal shaft up towards the top where it pivots and you will presumably then find the switch as shown in my image.
Again, we are assuming that it's in the same place for you as on our right-hand drive cars, even though we use a hydraulic clutch and you use a cable clutch.
Old 21-12-2017   #14
Moderator
g8rpi's Avatar
g8rpi has donated!
This modification may affect the hill holder (if fitted) functionality too. It would also affect cruse control but I don't think that's an option on the Panda.
Robert G8RPI.
g8rpi is offline Reply With Quote Quote
Old 21-12-2017   #15
Quote Originally Posted by g8rpi View Post
Robert G8RPI.
Nope, it doesn't affect the hill-holder. I can confirm that.
Thanks Deloki thanked for this post
(T) fiat 500 1.4 clutch switch pac238 500 2 14-06-2017 00:17
(T) Euro5 to Euro6 WoollyPanda Panda (2012+) 2 20-11-2014 19:57
