All the same problems have returned.
So i will start all over again to get them solved.
Oh Dear
So the garage has misdiagnosed the problem...... You should get a refund on the unnecessary work already done.
Good luck.
Oh Dear
Good luck.
It cost me nothing, all warranty work.
Thank goodness for that!!
Smart thinking. Is it just the start stop? How is your fuel economy now?Still 4 months warranty on the car, so if the Problems not have been solved by then, i will trade the Panda in, not planing to have a troubled car after warranty ends.
Did they check the battery 'health'?Start/stop is symptom not the cause.
Fuel consumption has not changed, still the same.
Yes, it’s flawless.Did they check the battery 'health'?
If they replaced it the first time it seems a second failure in a row is quite unlucky. Could it be that they misdiagnosed it originally?Panda is back at the dealer again for repairs, same issues occur again.
Oil Temp Sensor failure again.
I hope that it solves the problem.They replaced the OTS and cleaned the UNI-Air module to solved the problem, but it only did for 11 days.
Now the UNI-Air module get replaced by a new one as does the OTS.
Did you ever find the reason for the start stop problems?
