Might have made some progress with this issue. I put some additional oil in the engine, and also set the engine into ECO mode. Ran perfectly this morning with no loss of power, warning lights, nothing!
Hi.
You say you put additional oil in the engine. At what level was the oil at on the dipstick proir to topping up? Excessive oil is as damaging as low oil, seals can be compromised and crankshaft webs hitting the oil in the sump causes the oil to get aerated and results in low oil pressure. Also did you add oil of the correct spec?
