Phils panda Member Parked in the garage Joined Jan 18, 2017 Messages 357 Points 114 Apr 16, 2017 #1 Took fronts off to do a inspection but still dont no what this cap is for..advice wanted thanks..
M murphyv310 No Fiat now unfortunately Parked in the garage Joined Aug 19, 2010 Messages 1,616 Points 451 Location Kilmarnock Apr 16, 2017 #2 Where do the pipes go?
OP OP Phils panda Member Parked in the garage Joined Jan 18, 2017 Messages 357 Points 114 Apr 17, 2017 #3 Sorry i dont no..
The Pretender Patron member Parked in the garage Joined Apr 21, 2012 Messages 3,914 Points 1,012 Location The Centre Apr 17, 2017 #4 what engine has it. ?
OP OP Phils panda Member Parked in the garage Joined Jan 18, 2017 Messages 357 Points 114 Apr 17, 2017 #5 Ta 85
The Pretender Patron member Parked in the garage Joined Apr 21, 2012 Messages 3,914 Points 1,012 Location The Centre Apr 17, 2017 #6 I can't find that thing in mine, it's not there like yours.
OP OP Phils panda Member Parked in the garage Joined Jan 18, 2017 Messages 357 Points 114 Apr 17, 2017 #7 Is yours a TA 85 petrol.?
The Pretender Patron member Parked in the garage Joined Apr 21, 2012 Messages 3,914 Points 1,012 Location The Centre Apr 17, 2017 #8 Phils panda said: Is yours a TA 85 petrol.? Click to expand... Yes, late 2012.
The Pretender Patron member Parked in the garage Joined Apr 21, 2012 Messages 3,914 Points 1,012 Location The Centre Apr 17, 2017 #9 Maybe yours has dropped down from it's original place. But i could not see/find it in my engine bay.
OP OP Phils panda Member Parked in the garage Joined Jan 18, 2017 Messages 357 Points 114 Apr 17, 2017 #10 Hmmm,this top thing is attached mid line to a mid thickness plastic pipe.It cant go anyware.I will ring my fiat dealer tommorrow .
The Pretender Patron member Parked in the garage Joined Apr 21, 2012 Messages 3,914 Points 1,012 Location The Centre Apr 17, 2017 #11 Phils panda said: Hmmm,this top thing is attached mid line to a mid thickness plastic pipe.It cant go anyware.I will ring my fiat dealer tommorrow . Click to expand... What year is yours. ?
OP OP Phils panda Member Parked in the garage Joined Jan 18, 2017 Messages 357 Points 114 Apr 17, 2017 #12 20_2_12 on a 61 plate Last edited: Apr 17, 2017
J jackwhoo Distinguished member Joined Apr 8, 2017 Messages 6,123 Points 1,392 Apr 17, 2017 #13 It's meant to be right where it is. It is a clutch damper , in the clutch pipe.
J jackwhoo Distinguished member Joined Apr 8, 2017 Messages 6,123 Points 1,392 Apr 17, 2017 #14 People are probably confused because I have never ever heard of one fitted to a petrol engined car. Anyone else out there seen on on petrol car?
The Pretender Patron member Parked in the garage Joined Apr 21, 2012 Messages 3,914 Points 1,012 Location The Centre Apr 17, 2017 #15 Phils panda said: 20_2_12 on a 61 plate Click to expand... Mine is from 30 November 2012.
OP OP Phils panda Member Parked in the garage Joined Jan 18, 2017 Messages 357 Points 114 Apr 17, 2017 #16 So what damping does it do?? How does it work for the clutch...
OP OP Phils panda Member Parked in the garage Joined Jan 18, 2017 Messages 357 Points 114 Apr 17, 2017 #17 Whats is it purpose..
J jackwhoo Distinguished member Joined Apr 8, 2017 Messages 6,123 Points 1,392 Apr 17, 2017 #18 My understanding of function is to stop clutch pedal vibration when releasing the clutch pedal. Totally Different to damper springs fitted in the clutch plate. Hopefully someone else will post if ever seen on petrol before. On the diesels Prior to the part you have posted pic of the pipe was coiled a few times in approx ౩ inch diameter to attempt achieve same effects.
OP OP Phils panda Member Parked in the garage Joined Jan 18, 2017 Messages 357 Points 114 Apr 17, 2017 #19 Well thanks for the info..i've googled it but to no avail
M murphyv310 No Fiat now unfortunately Parked in the garage Joined Aug 19, 2010 Messages 1,616 Points 451 Location Kilmarnock Apr 17, 2017 #20 No matter what it is, it certainly doesn't look good, it's in line of getting damaged by road debris and the pipes could crack due to vibration. I'd be looking again to see if has come unclipped from something higher up.
