So, as can be seen from the photos, today I drove through a mud patch. It was me, with a somewhat heavyweight friend in the car (think about 100 kilos), and we almost got stuck. I had ELD on, the tyres have plenty of tread, and while the mud was deep, as can be seen from the deposits, it wasn't all that slick.
The issues I faced were, even with a running start in first gear, it would bog down at partial throttle. If I floored it, the ELD light would blink feverishly as what I assume (but couldn't confirm) mostly the front wheels spun. I just couldn't find a middle ground between momentum, throttle position, revs, and actual forward movement. Somehow, it also felt as if the rear wheels weren't really getting as much torque as they should as the fronts started to slip entering the mud. I had to do some danceworthy footwork between reverse and first to rock back and forth enough to get going again. While I did manage to eventually get us unstuck, this was the first time I was seriously worried I'd have to get the tow strap out, and I've managed not to get stuck like this going up a slick asphalt mountain road in a snowstorm.
I suppose I should be more wary of the saying "do stupid things, win stupid prizes" as there was a perfectly dry field I could have driven through instead of the mud patch. As you can see from one of the photos, I managed to kick up so much mud it looks like someone took a poo on the roof.
