Old 18-03-2017   #46
Moderator
g8rpi's Avatar
g8rpi has donated!
Re: Low oil pressure causing loads of errors
HI.
If you are split between two dealer get onto Fiat customer service and tell them you want your money back. You really should have told the supplying dealer as soon as you had problems. The local dealer will not be making anything on this so why should they put you ahead of customers who bought from them? (playing devils advocate here).
Rober G8RPI.
g8rpi is offline Reply With Quote Quote
Old 19-03-2017   #47
Moderator
Quote Originally Posted by Ceidio View Post
...so I bought it from a dealer in south Wales, Griffin Mill, who delivered the car to my home, for an unbeatable price (over 3.5k off) and with great efficiency. I haven't contacted them yet but I may well have to.
This may complicate things if you want to legally reject the car.
One important question before advising you further: are you the first registered keeper of the car, or was it preregistered by the supplying dealer?
"Just 'cos you're not paranoid, doesn't mean they're not out to get you"
jrkitching is offline Reply With Quote Quote
Old 19-03-2017   #48
I'm the first registered keeper. Fiat UK are aware of the supplying/repairing dealer issue. I will however get in touch with the supplier next week but I'm giving the repairing dealer one more (final) chance before I get a bit more heavy-handed.
Thanks jrkitching thanked for this post
Ceidio is offline Reply With Quote Quote
Old 19-03-2017   #49
Moderator
That helps; historically Fiat have been more generous to first owners when dealing with cases such as yours.
I'd agree that you should do everything possible to find an amicable solution to this. Going to law will be time consuming, stressful, and potentially costly. If you can agree a solution with Fiat CS, this will be the easiest and quickest way of dealing with your unfortunate situation. If it doesn't get fixed properly this time, personally I'd stand firm in asking Fiat CS to provide either a replacement new car or a refund.
Likes Ceidio liked this post
Old 19-03-2017   #50
2017 Panda City Cross
murphyv310's Avatar
murphyv310 has donated!
murphyv310 is an honorary friend of the forum :)
Hi.
I just wonder if the major problem here is the training given to these so called "Mechanics" is up to the mark. From what I can see is they are reading the codes and then have no idea how to proceed. It's all very well saying the TA is a high tech engine which it is but it still follows principals that that were laid down in the 19th century.
All the way through this thread I have read about the "garage" stabbing about in the dark with absolutely no fault finding. I have been in Electronics all my life and not only that worked in a garage workshop for many years at weekends stripping engines, gearboxes, clutches etc Oh and yes rebuilding them. The "mechanic" should be able to read the codes and work out what they mean and then proceed. The battery has been mentioned, It's a good staring point, earth's should have been tested, the loom should have been examined for chafing, plugs and sockets checked for loose connections or pins, time consuming yes but the adage of getting a repair done first time round seems to be sadly lacking here.
There could be an intermittent fault in the ECU or BCU or any other sensor, the senior tech should have been allocated the car and left with it till repaired, that way the customer would have been happier and Fiat wouldn't have egg on their face yet again.
Thanks Ceidio thanked for this post
Likes WoollyPanda, jrkitching liked this post
Cheers Trevor
murphyv310 is offline Reply With Quote Quote
(T) Low oil pressure warning light. Oil pump replacement? Marc Lewis Punto (Mk2/2b) 10 21-09-2019 22:50
(T) 110F Oil Pump options and low oil pressure woes marcus550 500 (Classic) 28 17-01-2017 22:02
(T) Low Oil Pressure light at low revs Sambo1 Stilo 3 17-01-2014 21:25
(T) Low engine oil pressure at low revs when hot Morty Mort Stilo 16 04-09-2012 23:28
(G) low oil pressure Sparanise 124 Spider (Classic) 3 03-08-2011 01:29
