FIAT Auto Specialist Team
Thread Tools
Old 25-09-2016   #1
SB1500 has donated!
Fitting a new DRL?
Apparently a Land Rover hit my granny's car and it's not half as bad as it sounds (see photos).
Going to order a new DRL and generic license plate holder.
Any bonus tips about cleaning the white paint?
It's a 2015 Panda Pop 1.2
2017 Fiat Panda Easy 1.2 - 27,050 miles
2005 Fiat Panda Dynamic 1.2 - 153,700
SB1500 is offline Reply With Quote Quote
Old 26-09-2016   #2
Re: Fitting a new DRL?
Can't really see the extent of damage in the photo, but if it's a scrape on the paint, then t-cut or a similar abrasive usually does a good job of getting rid of superficial paint or bumper marks from another car so you can see exactly what damage has been done to the underlying body/paint.
Chipex makes little paint-match kits which work very well on small scratches and chips and with practice and care can disguise small areas of damage.
Otherwise a 'Smart' repair (Chips Away etc.) is very good but it's prob going to cost you 100 or so.
hollister is offline Reply With Quote Quote
Old 26-09-2016   #3
SB1500 has donated!
It's so hard to photograph. Literally only the lens is half cracked
Old 27-09-2016   #4
There is a case for leaving small damage untouched, after all if it's not going to cause rust, it is just a 'battle-scar' making the car more original! Think tattoos or body piercing
Old 28-09-2016   #5
The DRL unit is fitted from the rear of the bumper by three screws. You should be able to access via the removable 'door' inside the front wheel arch. Turn the wheels to full lock to the right to give better access. Two screws hold the door/flap in place. There's another post somewhere which shows this door - use the 'search this forum' link and search DRL...
And you'll find this post: https://www.fiatforum.com/panda-iii/...ml#post4193388
Thanks SB1500 thanked for this post
2018 Panda 4x4 MJ :: North Herts :: Remember, if you find a post helpful, press the smiley face 'thanks' button below
Herts Hillhopper is offline Reply With Quote Quote
Thread Tools
(T) DRL again Mick F 500 48 23-12-2016 17:26
(G) Drl manxman020 500L 5 10-04-2015 16:30
(T) DRL, yes Again... Mac Evo Punto Evo 2 25-05-2014 15:46
Drl Buller Bodyshop 10 24-10-2013 17:38
(G) DRL's nickthegreek1958 500 3 18-10-2013 13:25
