Old 22-05-2017   #31
Re: Euro 6 engine software update letter?
It does sound like very similar issues and it may well be worth starting a new thread, especially as they may not be related to the software update.
The pedal was one of the possible culprits, but it looks like your dealer swapping that out has made that less likely. It's probably the same pedal gubbins as in all the other current Panda models, and likely in many other cars. That being the case, it would probably be happening elsewhere - which brings us back to the MTJ engine, the fuel input or the ECU.
I notice no difference from the car being cold, or warm, or having sat for a while. Whilst the engine is under load, and having to work to keep a steady speed or accelerate, it seems to be fine. It's only really noticeable when going along flat, or slightly downhill bits, or when coming out of junctions. If the engine isnít under load and the pedal position hasnít moved, or has been up and is then going down again, there are times when engine doesn't seem to be able to quickly decide what to do. The revs then seem to monetarily drop and you can feel the power surge off/on if moving, or it will stutter if coming out of a junction. Once she has made her mind up, then off she goes, albeit maybe not quite as strongly and smoothly as she normally would when sheís working well. All very frustrating.
MikeySkiBoy is offline Reply With Quote Quote
Old 22-05-2017   #32
2017 Panda City Cross
murphyv310's Avatar
murphyv310 has donated!
murphyv310 is an honorary friend of the forum :)
Sounds like old fashioned weak mixture. Make sure the plugs are properly gapped and not wide. I fitted Denso iridium plugs in my 1.2 and the difference was astounding. Certainly in the first instance it may even be an idea to reduce the existing gap by a couple of thou. Used to help cars with a slightly weak mixture.
Cheers Trevor
murphyv310 is offline Reply With Quote Quote
Old 22-05-2017   #33
murphyv310's Avatar
Sorry. My last post refers to petrol engines, I forgot we were discussing diesels.
Cheers Trevor
Old 22-05-2017   #34
Quote Originally Posted by MikeySkiBoy View Post
Thanks for all of your input mate...it's very much appreciated.
I'll start a new thread over the next few days when I get a chance to sit down at a real computer, then I'll shoot you a PM, or drop a link in here if there's a minimum post limit for PM's.
Quote Originally Posted by murphyv310 View Post
Lol...no problem mate!
Ventmore is offline Reply With Quote Quote
(G) Software update salmmi Croma 1 25-12-2012 17:17
(G) Free Software Updates Letter earthman Panda 14 03-02-2012 13:01
(G) Software update PandaLounge 500 28 01-02-2009 09:55
Good free letter writing software ? Koa Leisure Lounge 3 09-06-2007 23:51
(G) software update andy thrill Stilo 14 13-03-2004 05:31
