philboo
Member
Having had the message pop up on my car and the exclamation mark warning for several weeks I think I've sorted it and thought I'd share.
Having called my local dealer and being told it would be £95 to connect the computer and diagnose any fault before anything I decided to buy the ODB cables and reader and multi ecu software for £40. I was given help on the correct cable/reader by a fellow forum member which I was very grateful.
Having looked at the error messages mine referred to the brake switch sensor.
I'd previously thought my errors had been low battery voltage (as suggested on the forum) which initially did look like it was the issue. However after a few weeks they returned.
I noticed it would generally happen after I'd pressed the brake pedal gently.
I looked on here at other forums and found the punto listing issues with brake switch. I looked at the passenger side (on a uk RHD model as mine) and removed the under glove box fabric and then removed the brake switch. Having read the punto forum I reset this switch by pulling out the plunger and then reinstalling it whilst the brake pedal was depressed. The pedal was then released which pushes the plunger back in to the released position.
The switch itself seems to be two switches in one, one which is normally closed and one which is normally open when the pedal is in the normal un-operated position
I was having this issue every journey and after this I've not had the problem for a week.
Hopefully this may help someone else on here.
