FIAT Auto Specialist Team
Old 27-04-2016   #16
Re: OBD diagnostics
Quote Originally Posted by RQ3ZQTB View Post
Did you have a look on "memoscan" devices ??
I have one "U581" (an old one ...) and it works pretty well.
The first advantage is you don't need any computer at all.
I always keep it in my boot.
Regards
Hi. I have bought the elm 327 module that was suggested and adaptors leads which I've used without any issue with the MED software.
Thanks for the suggestion though.
Thanks varesecrazy thanked for this post
Likes jrkitching liked this post
philboo is offline Reply With Quote Quote
Old 28-04-2016   #17
France
Re: OBD diagnostics
Quote Originally Posted by varesecrazy View Post
AFAIK @philboo has now used MES to clear the faults and they have yet to return.
Sorry but I don't understand your reply ...
RQ3ZQTB is offline Reply With Quote Quote
Old 28-04-2016   #18
varesecrazy has donated!
See above post from philboo ;. )
Old 28-04-2016   #19
Re: OBD diagnostics
I'm not sure if i should post our recent experience with our Panda T/A,in this thread or start a new thread,it is related to the Diagnostics/Triangle of Doom,so i'll stick it here & see how it goes.
Our Panda recently had a factory recall for an indicator light problem,carried out at the Fiat dealer we bought the Car from(ex-dem),the recall was for some sort of update to the computer.
The indicator fault was corrected but a headlamp problem developed with the update,so the car had to be booked back in pending info from Fiat(which took 6 weeks)
To get to the main point,after the recall/download,the Triangle indicator light started to come on randomly so we reported this & where told it would be rectified when the car was in for the new download.
This has just been carried out but the Triangle warning was still coming on(along with a Stop/Start disconnected warning)
So the car went back to the dealer yesterday & we where informed that the triangle didn't come on while hooked up to the diagnostic machine,so they couldn't obtain a "CODE" for the fault,but the mechanic "thought" it may be a possible brake sensor issue,which predictably means we will have to pay for a new diagnostic check,because it's not connected to the initial indicator problem.
I'd appreciate any help words of wisdom about how to proceed with this,firstly should the Diagnostic machine have shown up a fault,even though the Triangle warning was not displaying.
Cheers,Graham.
Graham GB is offline Reply With Quote Quote
Old 28-04-2016   #20
Australia
Re: OBD diagnostics
Do what I did Graham, buy a Morris Minor with the plan of making it your number one vehicle once you get it sorted out
Modern cars are unnecessarily complicated and this sort of bulldust is part of the price we pay.
2014 Fiat Panda TwinAir
1960 Morris Minor 1000
I'm not mad, merely delightfully eccentric.
aussiepanda is offline Reply With Quote Quote
Old 28-04-2016   #21
Re: OBD diagnostics
Quote Originally Posted by aussiepanda View Post
Well,we already have a '61 Beetle,that we've had since '77,would that do
Not sure about using the Beetle amongst todays traffic & racing drivers in the UK
Old 28-04-2016   #22
Re: OBD diagnostics
Quote Originally Posted by Graham GB View Post
Cheers,Graham.
Well it's interesting they say possibly a brake sensor issue as that is the only reference to an error code my car had when I used the MES software. I've cleared this and will see if it happens again.
I did exercise the brake pedal and watch the system detect the two sensors related to brake position whilst doing all this and couldn't see any issue.
I had read some posts about the indicator recall but my dealer knew nothing about it when mine went in for a service a month ago.
Old 28-04-2016   #23
Re: OBD diagnostics
What i'm concerned about is,they are saying that they need to hook up the car to the diagnostic reader to detect if it is a faulty brake sensor(cost 100.00).
Should they not have seen a fault code when they hooked up to investigate the Triangle warning light?
Cheers,Graham.
Old 28-04-2016   #24
Moderator
Re: OBD diagnostics
Cheers,Graham.
Graham, how old is your car, and is it still in warranty?
"Just 'cos you're not paranoid, doesn't mean they're not out to get you"
jrkitching is offline Reply With Quote Quote
Old 28-04-2016   #25
Re: OBD diagnostics
It's a 2012 Panda Lounge,out of warranty.
Old 28-04-2016   #26
Re: OBD diagnostics
You're in a similar situation to me. Mine is just out of warranty and they wanted over 100 just to read an error code.
Annoyingly you seem to constantly have an issue but my error hasn't reoccurred after a long drive which I hope means it was just a low battery voltage.
If you plan to keep the panda for the 40 for the software and 15 for the reader and reads I think it's worth getting them and you can see what errors your car is giving out without the dealer.
I know on mine, the note of the software related to a brake switch issue says 'this did not illuminate the display warning light' or words to that effect so I don't know what the cause of my error was if it wasn't just a low battery.
Old 28-04-2016   #27
Re: OBD diagnostics
Thanks,philboo.
So from reading your reply,can i assume that the Dealer would have been able to read any existing/previous fault codes,regardless of the fact that the Triangle was not displayed when he hooked up our Car?.
Also with your reader box,if you took the information to your Dealer,would they act on the info,or would they still insist on using there own reader(100.00 charge),before carrying out any repair/work.
Cheers,Graham.
Old 28-04-2016   #28
Re: OBD diagnostics
Thanks,philboo.
Cheers,Graham.
From what I've seen the fault is hopefully logged regardless of the warning light. That said, I had a warning light and can't find any logged error which says the warning light would have been illuminated due to it. Hence why I now hope this was totally due to a low battery. I would hope that as the voltage can drop and rise through normal use and anyone can change a battery (not just a dealer) then that type of error may not even get logged. I'll know if it happens again as I'll plug in and look for an error.
I doubt the dealer would take my word for it but I would strongly argue that I would tell them what the error logged was and as such I don't see why I'd be paying another 100 to confirm something. This is my 4th fiat and to be honest it's been the most temperamental with the brake noise, dash rattle, poor start/stop, other random errors messages in the early days before a software upgrade and also I suspect the climate control has something wrong with it but the dealer could hear the load discharge sound I described when it was in for a service (sorry I digress). Each dealer seems to give very different service. I'm still waiting for word back on my brakes which apparently have been referred to Italy even though they been like this from nearly new and each year on the service I complain about them and have previously paid to have them striped and cleaned which lasted all of a week.
It all depends on how much information you want to be armed with. For me, 55 to have the facility to know before I take it in (and I can use time and time again) is worth it even though I also feel I shouldn't have to go through this to avoid dealer fees to plug it into a computer at their PC.
I can only imaging how bad this is going to get in the future with autonomous cars with highly precise radar, 3D cameras, etc.
Old 29-04-2016   #29
Moderator
Re: OBD diagnostics
Quote Originally Posted by philboo View Post
Have you seen this thread?
Properly lubricated (this isn't done on new cars in the factory, and likely isn't done by dealers doing a strip & clean, or pad replacement), the 500/Panda brakes will give many thousands of miles of trouble free service.
If assembled dry and used in the UK, one decent winter will quite likely ruin them.
The forum is littered with posts from folks who've needed complete disc & pad replacement after sometimes as little as 12 months/10,000 miles. I did this shortly after both my cars were delivered new; on the Panda, the front pads & discs worked faultlessly for 49000 miles before needing replacement due to normal wear. The 500 is now over 6 years old and about 34,000 miles; it's still running the original pads & discs.
The setup on those cars with rear discs seems to be the most problematic of the lot in this regard.
Pragmatically, on a car out of warranty, getting the whole lot cleaned & lubricated by someone who knows what they're doing is likely to be the easiest way of resolving your problem. Better still, do it yourself - it might not cost you anything at all if the parts are still good enough to reuse.
I welcome technical innovation - I don't want to go back to the 1950's - providing it's implemented using parts of sufficient quality to last the expected life of the product.
IMO the real problem is that the manufacturer's relentless drive for cheapness means these solutions are implemented using parts that are prone to premature failure and expensive to replace.
Old 29-04-2016   #30
Re: OBD diagnostics
Quote Originally Posted by jrkitching View Post
I'd read about this a while ago and honestly thought a dealer would at least do a reasonable job of applying copperease and cleaning them. I had always intended doing this once out of warranty but if it turns out the pads and or discs are Ruined I was hoping I'd get fiat to pay for them.
Thanks for linking to the post though. I'll certainly do this once I've a final decision from fiat.
(T) OBD Scanner / Live diagnostics synchro Bravo / Brava 35 15-01-2016 10:04
(T) OBD? Diagnostics? Superdad Stilo 1 17-05-2011 15:27
jtd's and obd diagnostics stilosporting Lets Talk FIAT 19 04-03-2008 18:04
OBD Diagnostics Fault Codes rcarter Lets Talk FIAT 0 27-10-2006 08:26
Diagnostics Gspot FIAT Boo Archives 1 27-06-2005 16:55
