- Dec 12, 2015
- 368
- 97
At my work i have a expensive professional one, that is very accurate.
Pffft. Jammy bugger. At my work, we've got lots of books, the only vehicles get the slaves to the place of purgatory.
Let me rephrase my statement.
I'm privileges enough to have, a expensive professional one at work, that is very accurate.
I had occasion to buy a couple of tyres in Switzerland a few years ago and they actually insisted that it would be illegal to put the new ones on the front.
What pressure do you put in your space saver spare?
The modern habit of manufacturing cars with wheel bolts instead of studs is one of my pet hates, because it can be so awkward to get the wheel correctly lined up when fixing a puncture up on the dark night. A four inch length of steel rod, of a diameter that will slip into one of the bolt holes, makes it much simpler to align the wheel on the hub.Now here's another question - if you had a flat right now, and had to change it at the roadside using only what's in the car right now, how would you cope? Is there anything you could do in preparation to make the experience less unpleasant?.
That's a great idea. From your answer it would appear that you've not had the need to remove wheels from your Fiat yet. You'll find that it has one or two small studs to locate the wheel, removing the need for your rod. These studs also hold the disc or drum to the hub.
Most Fiat's with wheel trims also have a clever larger bolt hole clockwise nearest the valve. You place the wheel onto the studs, insert that bolt finger tight, then on goes the wheeltrim. Then in go the other three bolts. Saves the struggle of juggling with wheel and trim together.
Should have added previously that, in my experience, the only safe place to pull off the road and change a puncture may well be on a slope or on soft ground. I always carry a couple of wooden wheel chocks (one of them was supplied in the toolkitof a 2CV that I ran for a few years in the 1980s) and a small plank (approx 400x125x20mm) to put under the jack......if you had a flat right now, and had to change it at the roadside using only what's in the car right now, how would you cope? Is there anything you could do in preparation to make the experience less unpleasant?
Having run a Panda Cross and a more recent Panda 4x4 MJ for a total of around 90k miles over fairly rugged terrain, and fitted wheels quite a number of times during those years (punctures, front-rear swaps, braking system maintenance, shock absorbers, drop links, etc), I do have relevant experienceof those models. (And of numerous light and heavy vehicles from different manufacturers, but not of any other Fiats).From your answer it would appear that you've not had the need to remove wheels fromyour Fiat yet. You'll find that it has one or two small studs to locate thewheel, removing the need for your rod.
