Old 09-01-2016   #1
Back door won't open, any ideas
2015 panda 4x4 - there is usually only me in the car so I rarely open the back doors but today when I tried passenger rear door won't open. All the locks are fine and the child locks are off. It will open from the inside but not outside. It will be a warranty call but any ideas how this might happen?
Going to get the squeaky rear brakes sorted (again!) while it's in!
cd1yat is offline Reply With Quote Quote
Old 12-01-2016   #2
Trader Rating: 1
R1NGA has donated!
Re: Back door won't open, any ideas
I bet you good money it's just stuck to the door seals. Mine does the same as I rarely use the nearside rear door. Open from the inside (to avoid damaging the external handle), clear and lightly silicon lube the seals and I am sure it will be just fine.
Thanks Tom95, deeyup thanked for this post
R1NGA is offline Reply With Quote Quote
Old 16-01-2016   #3
deeyup has donated!
Push it Champion
I agree, mine does it too.
Thanks worthy post.
deeyup is offline Reply With Quote Quote
Old 17-01-2016   #4
Australia
Quote Originally Posted by R1NGA View Post
Quote Originally Posted by deeyup View Post
Thanks worthy post.
I haven't had it on the Panda but did have it on the MG ZR - 2005 build so it could be something in modern 'rubbers'. Push bike tubes are the same, they perish after only a year or so being carried as a spare - you don't find out until you need them
If that is indeed the problem, the obvious way of getting around the problem is to open all doors regularly. Bit daft to just open them for no reason however, I've found that mine throws water and road grime up under the edge of the door and onto the sill - stopped by the seal of course. Therefore, when I wash her, I open every door and just wipe down that sill. Although I'm doing this to keep her clean, it should address the sticky door seals issue too through regular use.
2014 Fiat Panda TwinAir
1960 Morris Minor 1000
I'm not mad, merely delightfully eccentric.
aussiepanda is offline Reply With Quote Quote
Old 17-01-2016   #5
I'm me and proud of it
Bob Gill's Avatar
Bob Gill has donated!
Back door on mine (Panda 4x4 TA) won't open but pretty sure it's a dodgy switch - as child lock engaged can't open the darn thing at all - inside or out, manually or electronically. Apart from the intermittent reversing sensors no other problems. Off to the dealer I guess at less than 9 months old.
Bob
Bob Gill is offline Reply With Quote Quote
Old 17-01-2016   #6
Still waiting for a call back from the dealer to book in, sadly it won't open at all now
Old 18-01-2016   #7
Australia
Quote Originally Posted by cd1yat View Post
Bummer. Doesn't sound like stuck rubbers then
Old 19-01-2016   #8
May be unrelated, but, both my rear doors were stuck this morning - the -5C temperatures overnight must've frozen something in the locking mechanism, as the handles moved freely, but there was no resistance as if the lock/release was disconnected? Seals weren't stuck, the mechanism itself just didn't seem to work. 40mins of driving with heater on and they freed up. I put it down to the lock having damp in it that had frozen? Coming back to your issue, I wonder if there is gunge/grease build up in your locks?
I'm going to turn off the child locks to see if I could open from the inside if we have a repeat cold-snap...
Panda 4x4 TA Antarctica is offline Reply With Quote Quote
Old 29-05-2017   #9
Did you get anywhere with this issue?
The rear passenger door on my 14 month old 4x4 has just developed the same problem. The rear door simply won't open from the outside, but will happily from the inside.
The central locking makes the right sounds and the other doors can all be opened from the outside. However, that door's interior handle simply doesn't budge when the central locking is released. The only way to open the door is to pull that interior handle from its locked position, which then returns to the locked position when you let it go.
We've never had the child locks activated - but that would be back to front anyway.
Failing that, anyone got any ideas, or is it a back to the dealer job?
MikeySkiBoy is offline Reply With Quote Quote
Old 29-05-2017   #10
varesecrazy has donated!
Quote Originally Posted by MikeySkiBoy View Post
hi,
can you re-read what you've typed.. inside = outside..
does sound like a rod has dropped out from the latch mechanism..
Charlie
Likes The Panda Nut, MikeySkiBoy liked this post
Old 30-05-2017   #11
I got fed up of all the little niggles and sold the car in the end. No solution found for the door problem before it went.
Sorry to hear you are having trouble
Likes varesecrazy, MikeySkiBoy liked this post
Old 30-05-2017   #12
Sounds like it needs a trip back to the dealer then. Not a huge rush and a bit busy just now. I'll update the thread with what happens.
Old 07-06-2017   #13
I put some Carlube Silicone grease on mine.you can see were the sticky points are on the rubber.Apply the grease to the slighly rough areas.
Thanks PhilTwo Pot Panda LOUNGE
Phils panda is offline Reply With Quote Quote
Old 21-06-2017   #14
Quote Originally Posted by Phils panda View Post
It's not a problem with the door not opening at all, It's the fact that it won't open by operating the interior handle. It's just like having child locks enabled.
But it is good practice to put silicone on door rubbers! I have a spray can of the stuff that I squirt onto a cloth and rub that quickly over.
Old 21-06-2017   #15
g4jvf has donated!
g4jvf is offline Reply With Quote Quote
(T) Passanger door won't open ? matt1976 Stilo 15 22-12-2014 17:54
(G) Passenger door won't open Psyderman Ulysse 4 22-03-2014 15:17
(G) Help back doors won't open Loyalduke Stilo 1 17-09-2008 23:05
(T) Door won't open crainster72 Punto (Mk2/2b) 3 22-04-2008 14:46
Door won't open Marko FIAT Boo Archives 7 29-06-2004 22:42
