MikeySkiBoy
Possibly temperature related?
Nah. I'm afraid that it's not been that hot up here - just outside Aberdeen.
Can only think that whatever had moved out of postion, has now moved back................... until the next time!
It's only flippin' fixed itself! Not done anything to it and all of a sudden the door is happy to open again from the outside. Let's see how long this lasts.
So, the fix is to leave it alone for a few weeks, eventually get round to booking it in for a dealer visit and then try the door again the day before it's due to go to the dealer and then cancel the visit. Worked for me.
Flipin’ ‘eck! ours have self righted as well after being totally inoperative for 3 days. No idea why. Cooler air temperatures maybe?
Had a similar problem complicated by the child proof locks being engaged. Took back to main dealer under warranty and they managed to fix it. However, on close inspection a day later found there was damage to the interior panel and a number of pimple dents to the exterior bodywork.
Not impressed so took pictures and returned car to dealers.
After a few 'discussions' they finally agreed to repair and respray entire door and replace butchered interior panel.
Not a good experience from a Fiat dealer and not impressed with a certain amount of bull that was tried - possibly in an attempt to get me to accept a cheaper (for them) solution. A number of trips to the garage and being without the car for a number of days was more inconvenience.
Hope you get it sorted.
Bob
Did you get anywhere with this issue?
The rear passenger door on my 14 month old 4x4 has just developed the same problem. The rear door simply won't open from the outside, but will happily from the inside.
The central locking makes the right sounds and the other doors can all be opened from the outside. However, that door's interior handle simply doesn't budge when the central locking is released. The only way to open the door is to pull that interior handle from its locked position, which then returns to the locked position when you let it go.
We've never had the child locks activated - but that would be back to front anyway.
Failing that, anyone got any ideas, or is it a back to the dealer job?
Glad to hear this has sorted itself out!
Possibly temperature related? We've had some scorchers the past month or so, but it seems to have cooled down over the last week.
I know it's a late reply but it may help someone in the future.
I just failed my MOT because of this exact same issue, so I had to sort it out. The problem in my case (and I bet it's the same for you given the same symptoms): the little motor that actuates the lock was seized in the locked position, making it possible to open from the inside but not outide with the internal handle springing back in the locked position after pulling it.
In my case it was easy to unblock the motor after opening the latch mechanism. The steps are:
1. Remove the internal door panel (rear in my case). To do this there are 2 screws hidden behind two covers in the handles. If you have manual windows you have to pull the window handle until you uncover a steel omega shaped clip under the plastic ring, push it out with a screwdriver or similar. Then just pry the bottom of the door panel out of the door, these are just plastic clips holding it in. When no more clips are left, lift the panel upwards and it will slide up and come out.
2. Disengage the control cable from the internal handle (you have to unclip it by twisting the plastic terminal around the vertical axis, don't try to pry it out!) remove the fabric layer, and unscrew the latch from the side of the door (the 3 torx screws next to the child lock)
3. Free the lock from the electrical connector and the 2 control cables and open it up (there are 2 screws and a few latches). You will now have access to the motor as per picture attached. If it's locked and you can't turn it by hand, there's your problem. Try and turn the bronze gear with pliers and apply some wd40. Make it turn a few times until smooth.
4.Reassemble and enjoy!
The worst part is taking the window handle and door panel out, the rest is quite intuitive. The whole process would have taken less than 1h if I had this guide, and it was 100% free!
Looking at Shop4Parts - anyone have any experience with them?
