Thread Tools
Old 23-03-2019   #151
Re: 4x4 squealing rear brakes
Quote Originally Posted by gar074 View Post
My brakes don't honk
I spoke too soon, back at the start of this thread in October 2015!
I've never had any noise when reversing, but at 42k miles, and nearly 4 years old, the rear brakes on my Cross have started squealing with a vengeance! They are quiet for the first 10 minutes of a journey, after which the banshee wailing and screetching begins, until journey's end. Running with the handbrake on to clean the surface of the pads and discs makes no difference (apart from stopping the wretched noise temporarily while the handbrake is engaged).
Time to get the spanners and copper grease out, methinks! And I was looking forward to a nice, quiet weekend attacking the undergrowth in my garden.
Barchetta LE (no 2468), 1998, Silver with Red Hood and Red Leather Interior, Hardtop, Wind-stop, Novitec SS Exhaust
Panda Cross Twinair, 15 Reg, in glorious Yellow , replacing a much-loved yellow DS3 DSport THP
gar074 is offline Reply With Quote Quote
Old 23-03-2019   #152
It's very odd - this brake sqeal seems to be fairly common but I've never experienced it, either on my 13-plate 4x4 TA or its 100HP predecessor. I'm fortunate that my car spends most of its time in a garage with the handbrake off and I suspect this makes a difference.
babbo_umbro is offline Reply With Quote Quote
Old 23-03-2019   #153
Mine started squealing a week or so ago, discovered that one of the dust protectors had completely detached itself, ripped it out, problem solved��
gullyfoyle is offline Reply With Quote Quote
Old 01-04-2019   #154
Might be too late to be of help. Mine was rear brakes not releasing, you could feel intense heat from the squeaky one after driving. Was sorted with disc and pad change, although rear discs are not an easy job on the 4x4 I believe
steloveschips is offline Reply With Quote Quote
Old 01-04-2019   #155
Trader Rating: 1
The Panda Nut has donated!
Some pads have a thin shim bonded the the metal backing plate. Its not unheard of for these to part company with the pad. There are two options. Stick them back, or take them off and discard them. If the latter remember the pads will need renewing a little earlier as removal reduced the thickness by about 1mm. Its annoying but not restricted to Fiat brakes. Another possible fix is to remove the pads and chamfer the edges with a file this will also help reduce squeal. Remove any lip from the disc with a file or grinder while the pads are being checked. Ensure the Fiat 'mod' is fitted to the brakes too. This will be an FOC job at your dealer. With thorough cleaning and correct reassembly this lot should see you sorted.
Noop now known as Nooplebe (i.e. in the way wherever he goes) 🐼
The Panda Nut is offline Reply With Quote Quote
Old 02-04-2019   #156
Do you reckon they'll do that mod FOC for a car that's now out of warranty?
Old 02-04-2019   #157
@gar074 my Fiat dealer that was suggested the modification only relates to certain ages of car, paying for the modified parts to stop the noise 200 all in. I had my brakes cleaned out with a soft brush and calipers lubed (or whatever it was) for about 50.
Al D is offline Reply With Quote Quote
Old 02-04-2019   #158
Trader Rating: 1
Quote Originally Posted by PaulD View Post
Since the 'vibration dampers' have been fitted sometime in September I've had no recurrence of brake squeal, or any other noise. It seems to have done the trick.
Makes one wonder why the ** Fiat don't fit these dampers to all new ones now they know about the issue????????
Old 25-07-2019   #159
Bosnia and Herzegovina
Mine too. I drive used Panda Mk2 Climbing from 2008. Noise stoping when I pres break.
nikola bekic is offline Reply With Quote Quote
Old 25-07-2019   #160
I stripped mine down a few months ago, cleaned them thoroughly, filed the edges off the discs, chamfered the edge off the pads, copper-greased the backs, and, less than 3k miles later, they've just started squealing to high heaven again. Seriously p*ssed off!
Old 18-10-2019   #161
France
Lightbulb Re: 4x4 squealing rear brakes
Hi everyone, this is my first post. I'm an English bloke living in The French Alps. I've got a 'Sweet Candy Beige' 2017 Panda Cross TwinAir.
I bought the car in May 2019. The dealer told me that the brakes had just been done and the squeal would soon disappear. 3000km later it has got worse. So I did some research. I believe in France the warranty is just 2 years so I plan to do the work myself.
  • This video alerted me to the design fault:
  • I asked the guy for the part number, it is 52025558
  • This is now discontinued. It is replaced by 2 numbers 52077564 for the damper and 77365755 the screw
So to do both rear calipers you need to order:
2 x 52077564
and
2 x 77365755
You can order the parts here:
https://www.online-teile.com/fiat-er...64_Damper.html
https://www.online-teile.com/fiat-er...755_Screw.html
I've only just ordered the parts, so I'll post some photos etc.later.
The parts seem expensive for what they are, but if it fixes the problem I'll be happy.
PandaCrossInFrance is offline Reply With Quote Quote
Old 19-10-2019   #162
Thanks for this. After a relatively noise-free summer, mine has recently started squealing like a stuck pig again. Never heard a peep from it in reverse (which is what the video refers to), but on the move, especially at speed, it's horrendous at times, esp. when the brakes have warmed up. Very irritating. And those parts are stupidly expensive.
That video, though. Zzzzzzzzzzz...
Likes The Panda Nut liked this post
Old 19-10-2019   #163
@gar074 - how worn are your rear brakes? The pads have a metal 'tag' on them that, once the pads have worn close to their limit, is designed to make contact with the disc to make a really annoying squeal, to alert you to the need to replace them.
If you look at the parts in this photo, (click to zoom in) you can see the metal tag at the bottom left corner of the left pad in the photo https://www.eurocarparts.com/p/pagid...-pad-101581108
2018 Panda 4x4 MJ :: North Herts :: Remember, if you find a post helpful, press the smiley face 'thanks' button below
Herts Hillhopper is offline Reply With Quote Quote
Old 19-10-2019   #164
Not that worn! I've had them out several times now, so I know their condition intimately.
Likes Herts Hillhopper liked this post
Old 30-10-2019   #165
France
Smile Re: 4x4 squealing rear brakes
OK - it's all fixed. I had to buy the parts because my car is out of warranty, but it honestly feels like a different car now. The squeal has 100% gone:
https://www.youtube.com/watch?v=eBkEOtA-Pzs:)
Thread Tools
(T) Squealing Brakes Didge3 Grande Punto 0 05-06-2012 20:12
(T) Rear brakes squealing AdamP1991 500 16 10-03-2011 11:49
(G) Squealing Brakes Highlander 500 8 12-11-2008 00:30
(T) Squealing brakes ger Punto (Mk2/2b) 2 05-09-2007 22:59
(T) Squealing brakes Helz Bravo / Brava 7 16-02-2004 04:50
