gar074
Prominent member
Surprisingly, it got one star less than the standard Panda! It was marked down for, amongst other things, lack of standard safety assist tech. It also "failed to impress in Euro NCAP’s latest full width crash test”.
http://www.autoexpress.co.uk/car-ne...-and-suzuki-vitara-top-latest-euro-ncap-tests
The full test is here:
http://www.euroncap.com/en/results/fiat/panda-cross/20644
Apparently, having 4wd doesn't count as "safety assistance".
But an "autonomous emergency brake system" that stops numpties from ploughing into the car in front while they are texting is now essential kit if you want 5*. Oh, and a "speed limitation system", for those who can't be bothered to look at their speedometers!
I tend to look where I'm going when I'm driving, so I know which standard safety assistance feature I'd rather have! Problem is, Euro NCAP's scoring system doesn't contain a box to tick for 4wd, so the Cross gets no marks for having it. Crazy.
The poor showing in the new crash test is disappointing, to say the least. The section in the report on adult occupants makes for sobering reading:
"The passenger compartment remained stable in the frontal offset test. Examination of the dummy readings and the high-speed films revealed that the head had made contact, through the deflating airbag, with the steering wheel. A penalty was applied and the driver's head protection was rated as adequate. At around the same time during the impact, with insufficient gas in the airbag, the chest contacted the rim of the steering wheel and, combined with dummy readings for chest compression, its protection was rated as weak. Dummy readings indicated good protection of the knees and femurs of the driver and front passenger. Fiat showed that a similar level of protection would be provided to occupants of different sizes and to those sat in different positions. In the full-width rigid barrier test, protection of the driver's chest was marginal, despite the standard-fit seatbelt pretensioners and load-limiters. Without these, protection of the rear seat occupant was rated as poor for the head and the chest, and weak for the neck. In the side impact barrier test, the Panda Cross scored maximum points with good protection of all body areas. In the more severe side pole test, protection of all body areas was good except the chest, protection of which was adequate. Dynamic tests and geometric assessments indicated marginal protection against whiplash injuries for the front and rear seat occupants."
