Old 08-06-2015   #1
Unhappy Number plate lights and boot not working
Fiat Panda (2012) Twin air turbo Lounge trim
Ive seen a lot of threads about issues with the boot mechanism in fiats; mine wont unlock when the top button to unlock all doors is pressed, I have to press the bottom boot unlock button to be able to get in.
However along with this problem my number plate lights aren't working, at first I thought they had both gone, the dash told me this aswell, I changed them and nothing, checked the old bulbs and they where in full working order!
I read about the loom wire being an issue so I took off the back panel in the boot door and all of the wires look brand new; no tares or snags anywhere, no signs of any kind of damage at first sight.
I phoned the garage where I got it from (still in warrenty) and they where clueless and can only get it in next month!!! So i was wondering if anyone else had similar issues of these two problems occurring together, no other warnings appear on the dash, the number plate replacement warning light has now gone. Its clearly some kind of software issue, Im wondering if buying a diagnostics scanner and seeing if theres any codes that need clearing will do the job!
Caz89 is offline Reply With Quote Quote
Old 25-03-2018   #2
Denmark
Re: Number plate lights and boot not working
Did you resolved the issue? I have the same problem with my Fiat Panda 2007.
mrbeenir is offline Reply With Quote Quote
Old 25-03-2018   #3
Turkey
Considering this post is from 3 years ago, I'd say they probably did resolve the issue. Odds are, however, it seems like electricity isn't reaching the rear hatch. I'd check the fuse box first, and follow up by tracing the wiring.
oyumurtaci is offline Reply With Quote Quote
Old 25-03-2018   #4
Netherlands
And/or check the common ground/earth.
gr J
"Look for the ridiculous in everything and you will find it". - Jules Renard
A3jeroen is offline Reply With Quote Quote
Replacing number plate lights and side lights DazEvo Car Care 7 30-10-2014 16:20
(G) Number plate lights for a 56 plate Grande punto D8N13L Grande Punto 10 28-05-2014 17:42
(T) Number plate lights not working shortie 500 15 02-10-2013 06:56
(T) number plate lights/rear boot lock fredbear 500 5 04-02-2013 21:46
(T) Number plate lights not working Horney Cinquecento / Seicento 1 01-12-2005 17:23
