The reason the rev limiter cuts in earlier in 1st and 2nd is typically due to the rapidly rising revs in the lower gears and the potential to over-rev due to the inertia in the reciprocating mass. The rate of increase in revs in the 4x4 TA in 1st gear is quite alarming and the rev limiter cuts in at about 5400rpm or thereabouts from what I can tell. But the inertia can allow the engine to spin nearer to 6000rpm before I can get into second, such is the motor's enthusiasm and low gearing. Try the same full throttle acceleration in 3rd or 4th and the limiter waits a few 100 rpm later, as the rate of engine rev build is that much less and therefore less chance of it banging into more damaging rev levels.
I'm now on about 13,000 and the engine is definitely stronger (and more economic, although perhaps not at the same time!) than it was at 3000 miles. I have high hopes for a long and reliable life with my TA, but do make sure you change the oil every year at a minimum, regardless of miles or whatever the service indicator or service book says!
