Old 07-07-2016   #61
Re: Panda Start Stop Fix
Quote Originally Posted by Mercky View Post
Well I got mine under warranty after 2 years but I had reported issues early on, it was more of a good will gesture tbh as I have a good relationship with them. If I was you I'd bite the bullet and just buy one but make sure it's fresh and designed for SS. It does make driving the car more enjoyable when it works correctly, also my mpg went up significantly partly due to less load on the alternator but also obviously with the engine cutting out more frequently and for longer. As a plus you can use the old battery in a non SS car as it will work just fine for years to come.
I was just about to order one today, when the S/S decided to work this morning! I'm going to try and make it to the colder months start before ordering.
Thanks, W.
WoollyPanda is offline Reply With Quote Quote
Old 07-07-2016   #62
Netherlands
Pulled the F90 fuse today, but it changed nothing.
Still no working start stop.
There are Pretenders among us.....
Geniuses with the ability to become anyone they want to be.
Abarth 595 Turismo.
The Pretender is online now Reply With Quote Quote
Old 13-07-2016   #63
Quote Originally Posted by The Pretender View Post
Yes, it only worked for few days for me before refusing to switch off. I'm going to charge the battery overnight. If it then works then I know its the battery at fault.
Old 13-07-2016   #64
Full Circle
Mercky has donated!
Ireland
Quote Originally Posted by WoollyPanda View Post
Note it takes a few miles for the SS System to relearn the battery after a charge if you disconnect, incidentally charging made no difference to mine
Mercky is offline Reply With Quote Quote
Old 13-07-2016   #65
Netherlands
The first of August mine will be serviced, most likely they will tell me what the problem is.
Abarth 595 Turismo.
Old 18-07-2016   #66
Does the battery need to be disconnected to charge it? (It will be a trickle charger.) I know not to connect the charger directly to both the battery terminals, just the positive on the battery and an earth elsewhere but wasn't aware you had to disconnect it completely.
Thanks.
Old 19-07-2016   #67
Trader Rating: 1
R1NGA has donated!
Thanks.
You shouldn't need to and you can connect the charger directly to the battery in normal circumstances - it really shouldn't do any harm. But I'd recommend buying one of the modern 'intelligent' charges that trickle, boost, condition and all many of other things automatically. I have a brace of CTEK chargers for my cars and very good they are too. Similar to this;
http://www.ctek.com/gb/en/chargers
R1NGA is offline Reply With Quote Quote
Old 20-07-2016   #68
Quote Originally Posted by R1NGA View Post
I didn't get around to charging the battery but the SS started working all by itself today! I still intend to give it a charge when it decides to stop working again.
The reason I ask about how to charge the battery is that I was told by a dealer NOT to charge it directly on the terminals because the battery has a meter that can be damaged by charging it directly. I find this hard to belive if using a modern, "intelligent" charger as you described, which is the type I'll be using. Maybe if it were a heavy duty "boost" start or using jump-leads this might be true?
Old 21-07-2016   #69
Trader Rating: 1
R1NGA has donated!
I think I'd tend to agree. S/S is very voltage and battery condition sensitive, so only it will decide when it wants to work. I doubt there's much wrong with it that a drop of longer, lower current-draw journeys wouldn't cure.
Old 21-07-2016   #70
Moderator
Believe it.
I was given a printed sheet of instructions and had to sign a declaration that I'd understood this specific point before being allowed to drive my new 500 out of the dealership. This was when S/S was first introduced as standard; apparently they'd had cases where customers had damaged the system by charging the battery across the terminals and Fiat had refused a warranty repair.
If you need to charge the battery in the car whilst it's still connected, you can do so safely by first attaching the positive lead to the positive battery terminal, and then attaching the negative lead to a secure earthing point on the chassis. Disconnect the leads in the reverse order.
This is good practice on any car, as it also mitigates any risk of a spark causing a battery explosion (it has happened).
The same rules apply to using jump leads, only more so due to the much heavier currents involved.
"Just 'cos you're not paranoid, doesn't mean they're not out to get you"
jrkitching is offline Reply With Quote Quote
Old 21-07-2016   #71
Trader Rating: 1
R1NGA has donated!
Quote Originally Posted by jrkitching View Post
Believe it.
Well you learn something every day don't you - thanks for that
Old 14-03-2019   #72
Exclamation Re: Panda Start Stop Fix
Hello everyone. Not sure if I am putting this in the correct place so apologies if I am not!
I fitted a new clutch and dual mass flywheel to my 63 reg 4 x 4 twin air, since then the little orange exclamation mark warning light comes on after about a mile and then stays on.
When it comes on a message on the dash tells me that stop start is unavailable which I don't mind as I don't like it/use it but the light is irritating.
Have tried the battery top up (It's new and fully charged) and had the light/fault turned off by two different computers.
Any ideas for me folks?
Many thanks.
Dobcrosser is offline Reply With Quote Quote
(T) Panda 2012 twin air stop start problems dogsense Panda (2012+) 35 03-02-2019 21:10
(T) Panda 0.9 Start Stop niggles pandapops Panda (2012+) 76 22-01-2014 07:36
(T) Panda Twinair Stop Start issues Uglyscotsguy Panda 15 04-12-2013 10:22
(T) Start&Stop in stop-and-go traffic Mondaugen 500 63 17-10-2011 07:07
(T) Start stop - How long does yours stop for? Ransoman Punto Evo 9 17-08-2011 11:52
