babbo_umbro
Established member
Having set off for our home in Umbria on the 3rd of April we returned to Devon on 23rd June. This was the 4x4 TA’s second Italian trip and the little car acquitted itself well again. The total milage over the period was 5990 miles - including 2500 miles going to and from Spoleto - with the balance covered on greater than usual travelling around while in Italy. Overall mpg was just under 41, rising to 42.something while taking trips in Italy but being brought down again by motorway cruising at - or around - the legal limit going to and fro. Coming back we had 130 or so kilos of load, mostly wine and olive oil and equivalent to an adult and a youngish teenager, so the car was not overloaded but earning its keep. Air con was on for at least 80 percent of the time, either for cooling or for coping with extreme wet/misting conditions.
Motorway performance is the big differentiator between the MJ and the TA; the TA engine has such a flat torque curve that it cruises happily at any speed between just over 3000 revs - say 70mph - and about 4300 revs or so - say 90 mph (if allowed). A couple of dashes to Rome to do charity gigs could well have seen a constant 90 or so all the way without any obvious strain and with a small degree of acceleration in reserve (if you see what I mean). Main road hill climbing is impressive, with speed maintained comfortably up long Alpine inclines; while the 100HP - still missed for its handling and remembered with affection - would need to be doing something close to 5000 revs to really pull, requiring a change down, or two, the 4x4 just keeps tugging. Cruising in the 100HP always emphasised that its best rev band was so high that you’d be doing highly illegal speeds in sixth, the TA is more suited to give and take motorway conditions. The 4x4’s brakes inspire confidence under all conditions; the M&S tyres make some noise and their relatively high profile gives a fair degree of squidge but the general handling and driveability is fine. The car has done about 1400 miles in its first ten months and tyre wear is very moderate. There was some mention of oil consumption in recent posting; I had a precautionary oil change done after 5000 or so miles (not liking the idea of keeping running-in oil in the engine for the 18000 mile service interval); I did a level check before setting off in April, filling up to minutely above the full mark on the dipstick and the level doesn’t seem to have shifted in the 6000 miles since.
The 4x4 has really come into its own around the minor roads in Umbria. Our house, for instance, is over half a mile up a white (gravel) road; lack of maintenance and several bouts of torrential rain have taken their toll, with numerous areas down to bed rock and as many areas with two or three inches of loose gravel; there are some steep sections - 1 in 4 or so - where stopping for some reason - sheep and accompanying dogs, horses, people, wild boar, porcupines, hoopooes - in descending order of likelihood - would make re-starting tricky at best in the 100HP, the 4x4 coped with no issues. About 300 yards short of our house there’s a heavily eroded section where the 100HP simply couldn’t get past without loosing its exhaust but the 4x4 has no problems. A Trekking could obviously cope similarly with the ground clearance issue but I'd be interested to see how it would restart on a steep loose surface; it also lacks the six-speeed box of the 4x4.
All-in all the 4x4 TA is all I expected it to be - a straightforward, honest, small Fiat - and perhaps a little better than that. The new model Panda has certainly appeared in very large numbers in Italy, with a high proportion of 4x4s in the mountainous, country area of Umbria. My only, minor, negative comment is that I still don’t like its looks, I think it’s much less visually appealing than the previous model.
