Old 04-05-2018   #61
2017 Panda City Cross
murphyv310's Avatar
murphyv310 has donated!
murphyv310 is an honorary friend of the forum :)
Re: Engine Oil For TwinAir.
Quote Originally Posted by Torsten S View Post
In this thread you yourself provided evidence that you used the wrong oil and didn't adjust the uniair control parameters after the oil change - that's what I mean with "without the expertise". But I'm afraid you are in good company, as many Fiat garages don't know this and will happily tell you that all twin airs need any 5W40 and have no clue that there is another routine to be performed on the computer.
Hi.
An eye opener indeed.
It is very worrying that there is a feeling the Fiat service engineers are not doing the job correctly. Do we have the evidence that they are not re-setting the parameters for the uni-air module after an oil change?
Does the ECU have stored details of how many times this re-setting is done, I know other vehicles log the number of accesses and what parameters were changed and stored.
If there is sufficient evidence that this wasn't reset then surely this could be taken further and the service department taken to task.
The other snag is there are still some like me that goes out and buys a clean low mileage used car with the intention of keeping it for some years, I have additionally rust proofed it on the rear beam, subframe and other obviously potential rust spots, I do an additional oil change every 6 months and use quality Iridium plugs and don't skimp on maintenance. So my point is if you are a TA owner and are unaware of this reset you need to do as no doubt a general garage is as well what harm are you doing to the engine and lets be honest is this another ploy for dealer only service work?
Cheers Trevor
murphyv310 is offline Reply With Quote Quote
Old 04-05-2018   #62
Its resets it self after the car is driven after the service.After speaking to my garage info he says new diesels need resetting to tell the ecu about the condition of the oil in percentage of use.
Thanks PhilTwo Pot Panda LOUNGE
Phils panda is offline Reply With Quote Quote
Old 05-05-2018   #63
Quote Originally Posted by Phils panda View Post
Your garage is mistaken. How will it know to reset itself? Magic?
My own garage was convinced that a 2016 twin air needed 5W40 oil and did not know about the reset. So treat information given by a garage, even if it's a main dealer, with a pinch of salt.
That's why I said earlier that I'd rather do services myself.
I'll trust the information given by the manufacturer.
This may be a general problem with modern cars: You need an engineering and computer science degree to really understand them, and traditional garage wisdom (like the above) is obsolete.
Likes jrkitching, murphyv310 liked this post
Torsten S is offline Reply With Quote Quote
Old 05-05-2018   #64
murphyv310's Avatar
Oil degrades as we know but it degrades differently dependent on what type of running a car has.
Starting a car up every morning and doing a lengthy motorway trip will impose different conditions to the car that does a two mile trip on every cold start.
Short runs cause the oils viscosity to increase due to a reaction between condensation and the oil, one reason I advocate a six monthly change for vehicles doing short runs. I'd suspect a TA would not be a good bet for short run usage. I'd also say a TA would be an ideal engine for motorway and high mileage.
Just my meanderings.
Likes Torsten S liked this post
Cheers Trevor
Old 06-07-2018   #65
Panda Twinair Lounge
Vic20 has donated!
Well, I've bitten the bullet and changed the oil in our 2012 Panda to Selenia 0W-30. (this stuff almost pours like water!)
Based on the fact that the part number for a uniair module for a 2016+ Panda is exactly the same as for a 2012 model, I reckon that's going to be pretty safe. Also, doing it at these extreme ambient temperatures, I'll see immediately if there are going to be any other issues
On changing the oil, I reset the Uniar module in ECDS and , Unlike the previous occasions when using 5W-40 the engine immediately ran smoothly and continues to do so, much quieter and smoother than previously especially when cold.
I'll continue to monitor factors like Oil consumption closely especially in these 30+ degrees ambient temperatures but my immediate feeling is the Uniair is much happier running with this oil.
You never know, the always high Lambda figure may improve significantly at the next MOT (likely indicating that the inlet valves are closing faster now)?
Likes R1NGA liked this post
Vic20 is offline Reply With Quote Quote
Old 06-07-2018   #66
Moderator
Quote Originally Posted by Vic20 View Post
Things aren't that simple. Even if the hardware is the same, the software controlling the operation of the uniair module may be different.
Read this post for a more detailed explanation.
Based on everything we know so far and in particular the INA Schaeffler technical document linked here, my recommendation is to use only the specific grade and specification (though not brand, provided it's the correct grade and spec) of oil recommended by Fiat for the particular year and model of your car. Experimentation could lead to engine damage, including uniair module failure, and is not recommended.
I'll leave the final words to the technical guys at the company which designed the uniair system.
"Just 'cos you're not paranoid, doesn't mean they're not out to get you"
jrkitching is offline Reply With Quote Quote
Old 06-07-2018   #67
Vic20 has donated!
[QUOTE=jrkitching;4345120]Things aren't that simple. Even if the hardware is the same, the software controlling the operation of the uniair module may be different.
Well, perhaps I'm on level terms with things now, In trying to fix the failed indicator stalk recall which resulted in the headlights lights permanently on, the dealer said he also updated the engine management software to no avail in fixing the problem.
This car, at 6 years old is NEVER going back to a dealer now so it's my call!
Likes jrkitching liked this post
Old 06-07-2018   #68
I changed mine only yesterday..61 reg TA LOUNGE 38,600 miles..Triple QX 5w40 fully syn c3 also for PD Engines.. runs a treat..
Old 23-08-2019   #69
Having read this thread I told my mechanic to out 0w30 in my 2014 0.9 85hp twinair euro 6. He insisted he'd spoken with Fiat (he's a friend not a specialist) and they said he had to use 5w40. So I checked my car's manual and sure enough it said 5w40. So it seems the earlier euro 6 cars may still run on 5w40.
eshroom is offline Reply With Quote Quote
Old 24-08-2019   #70
Changing mine tormorrow now on 47600 mine and still 5w40 c3Click image for larger version
(T) TwinAir OIL consumption..?? varesecrazy 500 106 4 Weeks Ago 06:36
(T) Twinair engine oil ...when is an oil not the correct oil ? iangray100 500 20 04-09-2020 17:31
(T) TwinAir oil and filter change nemchenk 500 45 23-03-2014 09:05
(T) TwinAir oil min/max nemchenk 500 29 17-01-2012 23:59
