Old 03-02-2014   #1
Panda Twinair - fumes in car
Got a 63 plate twinair that leaves a faint smell of exhaust fumes inside; particularly in the back of the car. Turned off the stop/start (which seemed to be contributing to the problem) but no solution yet. About to ring the dealer but wondered if anyone else had experinced this problem.
dopes is offline Reply With Quote Quote
Old 03-02-2014   #2
triumph7 has donated!
Re: Panda Twinair - fumes in car
Quote Originally Posted by dopes View Post
No.....
triumph7 is offline Reply With Quote Quote
Old 03-02-2014   #3
No - though I'm a bit surprised as the exhaust pipe doesn't clear the bodywork. On a very new car you can get hot paint smells. The oil filler's pretty foolproof, even for a "professional" mechanic, so spills there are unlikely. Do you have a carbon monoxide alarm handy?
babbo_umbro is offline Reply With Quote Quote
Old 03-02-2014   #4
It's never been an issue with either of our TA engined Fiats.
500 TA Lounge
Panda 4X4 TA Antarctica
TwinAir Newbie is offline Reply With Quote Quote
Old 03-02-2014   #5
You must have an exhaust leak somewhere.
I'm still not 100% convinced about Fiat build quality.
Shaston is offline Reply With Quote Quote
Old 03-02-2014   #6
Speed Reader of the Year!
Most Easterly Pandas's Avatar
Trader Rating: 2
Most Easterly Pandas has donated!
Does it have a rocker breather pipe like the 1.2's
If so this might have failed, is worth checking.
Most Easterly Panda's - Panda'ing in East Anglia
Stockest of mk2 Panda Parts, PM for any parts requests
1993 Classic Panda Selecta, 1989 Panda 750L,
2015 Kia Soul EV, 2009 Panda Eleganza & 2005 Panda Climbing 4x4 (LPG)
Most Easterly Pandas is offline Reply With Quote Quote
Old 04-02-2014   #7
Trader Rating: 1
portland_bill has donated!
In the boot, at the rear, maybe below the carpet will be the vents that allow the air to flow through the car. These should have simple flaps. Check they are undamaged.
When reversing, it is common to get fumes, as we reverse over our own exhaust fumes. I assume you have the problem when going forward too. If however you reverse off the drive first thing, you will get a lot inside. That may take a while for the smell to go. Could this be it?
After considering the above, as said above, check engine breather pipes and exhaust for leaks.
Problem still there? Does the tailgate seal properly? Put talc on the seal and close the door gently against it. Reopen and check it has connected all around.
You do have the heater fan on at least 1? Keeping it off will give you very little fresh air, retaining any fumes inside for longer.
13 years motor trade, 16 years motor industry. 14 years Driving Instructor & 7 years Fleet Trainer
Panda Alessi
portland_bill is offline Reply With Quote Quote
Old 04-02-2014   #8
Thx for these ideas - I'll let you know how I get on.
DP.
Old 10-02-2014   #9
I had this problem to a small not-too-bothersome extent on a 500 convertible i had for 6 months last summer. Kind of an unburnt petrol in the exhaust fumes kind of smell sometimes noticable in the car.
mwcf is offline Reply With Quote Quote
Old 21-02-2014   #10
The answer was a plastic bag that had managed to wrap itself round the exhaust and had started to melt. So plus side the car has no problems - downside I should have discovered that before posting here. Thanks for the ideas - much appreciated. If I cannot tell the differenec between exhaust fumes and melting plastic it explaisn my lack of a wine palet.
Old 21-02-2014   #11
Glad that's cleared up
On a slightly related note, with all the floods I wonder how vulnerable is
the 4x4 and Trekking's exhaust system to thermal shock when wading
I can't find any mention of this in the manual. Thankfully, the worst is
over, and levels are now dropping here in the upper Thames Valley
Chris
Moultoneer is offline Reply With Quote Quote
Old 21-02-2014   #12
Dunno but I. Seem to have survived about a foot of water unscathed. That was the deepest bit.
(T) Fumes in car andyf1234 Grande Punto 3 01-03-2014 20:18
(G) CAR magazine - Fiat Panda 0.9 TwinAir (2013) long-term test review Super Uwe Panda (2012+) 1 16-08-2013 13:26
(T) Petrol fumes in car Ian2011 Punto (Mk2/2b) 6 17-01-2013 10:35
(T) Panda Exhaust Fumes in Car Bobfreeman Panda 1 25-06-2012 19:43
(T) Fumes in Car maxi26 Uno 2 09-12-2011 17:31
