Been into the dealer today to cure the curious owl-like noise on reversing.
Discs and pads replaced under warranty. Hopefully cured now!
Thanks for the update. I really need to get my backside into gear and have a word with my dealer about it. It actually hasn't been quite as bad recently but it still does it. Also my occasional exhaust/heat shield rattle from the rear has occurred a few times recently which I want to get sorted before I get a tow bar fitted.
You can replace the discs and pads as often as you like, but unless you do this, any solution will most likely only be temporary.
My car is going in for 'assessment' tomorrow and I also have a case open with FIAT about is as ' brakes aren't covered by the warranty'.
Just noticed mine doing it today, although dont go in reverse very often and goes down muddy lanes every day! Only 1300 miles
For obvious reasons there appears to be quite hefty brakes on the 4x4. I would guess that on a vehicle used solely on the road, the rears don't do a huge amount. Perhaps occasional heavy braking might stop them sticking. Just a thought.
Ive just had my brakes looked at by the dealer :bang:. They will not replace the pads, they said "the brakes just make a noise,thats the way they are". Sorry he was just talking out of his arse, I have not read in the spec that the brakes will squeal there arse off. Anyway a call to fiat might be in order then after that I might fit some quality pads . I'll keep you posted.
Fiat authorised my dealer to replace rear discs and pads saying that they were distorted and a faulty batch......
Just to let you know I've left my car back with the dealer this week while in working away and they are going to fit new pads and or discs to see if that sorts it. Still having the 'discussion' this fiat who pays (I have so far).
On a more positive note when I was in last time and they cleaned the brakes they did two software updates as I mentioned the 'ELD unavailable' messages randomly at start up. I've not had this happen again since the updates so hopefully that's one thing fixed.
I also feel the gear change indications and lower rev e.g 1500-2200 range has felt better since. Probably imagining it but it all.
