beeson100
I hope the other Twinair owners might be able to help with something I have noticed which I'm not sure is normal or not.
In a high gear at a relatively low speed (around 30mph for 4th and 40mph for 5th which is around 1500rpm in my 5 speed Trekking) when blipping the throttle the whole car judders. There is the intentional delay with the fly-by-wire system so it happens about half a second after pushing the pedal but also when taking it off. It becomes more noticeable the quicker I push the pedal and pushing in and out causes the whole car to kangaroo along with an accompanying rattle somewhere in engine bay which sounds quite worrying. This rattle and shaking also happens continually if I labor the engine by putting it in 5th and accelerating from 30mph. This isn't my driving style, but I don't think it should be doing this.
I don't remember this happening when I first got the car but then I may just not have noticed before. Could someone please confirm if theirs also does this?
I've also got a knock/pop sound when pushing the clutch in to change gear which is only noticeable when changing up from the lower gears but I'm not sure if it's related to the judder issue or not.
The dealer had the car back for 4 days but couldn't find anything wrong. They changed the master cylinder hoping that was causing the pop sound but it hasn't made any difference and I don't think they even looked at the shaking issue. It's going back in again this Thursday for 'The Inspector' to have a look but I've already been told what I am hearing could be normal!
I've read a couple of others having issues with the clutch but the symptoms seemed a bit different. Hope someone can offer some assistance!
John
John
