E elofan Member Joined Nov 25, 2013 Messages 18 Points 59 Dec 24, 2013 #1 Hi I want to change the drl bulbs for led ones and I have removed the bulb unit from electrical connector but I can't seem to remove the actual bulb from the unit is it a sealed unit I can't seem to turn or remove bulb at all
M millns84 New member Parked in the garage Joined Mar 1, 2012 Messages 75 Points 18 Dec 24, 2013 #2 Push down on the bulb slightly and turn anti clockwise
OP OP E elofan Member Joined Nov 25, 2013 Messages 18 Points 59 Dec 24, 2013 #3 hi millns I have tried that bulb will not budge at all it doesn't have any movement at all any ideas??
