im Axle Specialists
Thread Tools
Old 01-10-2013   #61
deeyup has donated!
Push it Champion
Re: removing roof rails.
Quote Originally Posted by triumph7 View Post
U having roof sprayed or vinyl? If the latter how did u resolve the aerial issue?
Look forward to seeing it
Didn't get done. He was a little late getting to it and may have rushed it so we said do it another time. In the meantime my car is at Griffin Mill having the stop/start issue looking at. I've got a Qubo multijet, and I like it
Likes triumph7 liked this post
deeyup is offline Reply With Quote Quote
Old 01-10-2013   #62
triumph7 has donated!
Quote Originally Posted by deeyup View Post
.....not more than the 4x4 surely?!?
triumph7 is offline Reply With Quote Quote
Old 01-10-2013   #63
deeyup has donated!
Push it Champion
No, I wouldn't swap it.
The multijet motor is good, and damn economical. 62mpg today which I reckon would have been around 46 in my car. Don't know what power it is?
It did feel a little slow though.
Another thing, the speedo is bang on. 50mph indicated is 50mph satnav.
It was vinyl btw I was having on the roof.
Old 01-10-2013   #64
Good. Look forward to seeing it. What about the aerial?
Old 02-10-2013   #65
deeyup has donated!
Push it Champion
Don't know on the aerial. I would have though that there will be a straight cut from the aerial to the tailgate so he can get over it.
I'll be happy enough with that as I think the potential to damage something lowering the headlining is the worse of the 2 options.
Monday now is the date.
My mirror caps are being painted tomorrow which btw, I'm having 2 sets painted as it is not a lot more than 1 set. Anybody want a pair?
Old 02-10-2013   #66
Yes that's what my people said. If the aerial not removed there will be a short cut line from aerial to tailgate. I must say I admire the way they do this as I get air bubbles putting a tiny screen protector on my mobile! Lol
Is painting a viable alternative to vinyl?
Old 02-10-2013   #67
deeyup has donated!
Push it Champion
Painting would be good. I was in 2 minds whether to paint or vinyl.
The guy I use for paint is flaming good and cheap, not a combination you usually find.
I thought though that vinyl can come off easily if it needs to.
If Monday gets cancelled again, I may just get it painted?
Old 08-10-2013   #68
Did u get the vinyl wrap done?
Old 08-10-2013   #69
deeyup has donated!
Push it Champion
Going in for painting on Friday.
I couldn't make the car available yesterday for the vehicle graphic guy so I thought stuff it, the painter is a walk from my house so it's easy for me.
It's nigh on the same price too. I'm removing the roof rails and the Bodyshop are taking care of the headlining to remove the antenna base.
Goes in Friday morn and collect end of the day. He has my mirror caps done too.
Old 08-10-2013   #70
Great! Look forward to seeing it. My only worry about paint is its permanency if I change my mind later. Haha
I wonder if its really necessary to remove the roof bars as the new colour is only on the part of the room between the bars? Are you getting the top section if the hatch done too?
Old 09-10-2013   #71
deeyup has donated!
Push it Champion
So I took the roof rails off today in preparation for painting. I think they will get a better finish with them out of the way. I am getting the top of the hatch painted too in answer to your question triumph7
It was a simple job to remove the bars and I'm sure anyone would manage without this, but I took pics in case anyone did want to see what's what?
First remove the end caps of the bars, fore and aft. They just pull up and off.
This is the front one. Be aware that the forward part is stuck with double sided tape so be careful you don't snap it.
This is the back one with the covers removed.
The front part of the bar here with the cover removed. I've already undone the Allen bolt here any you can see it.
Next remove the 2 little caps on the top of each bar. A small flat blade screw driver takes car of it. Take car not to scratch the aluminium bar.
There are some more 5mm Allen bolts buried in there. You'll need a longer Allen key for these. My socket set one wouldn't fit.
Once these are out the bars just lift clear.
You are left with these welded on brackets
And this is how the car looks without the bars for @The Pretender
When I put the bars back on I will be applying liquid threadlock to keep them in place.
Thanks triumph7 thanked for this post
Likes alamar, triumph7 liked this post
Old 09-10-2013   #72
Liquid threadlock? Can the bolt just be put back in? I guess it will be better job with bars off.
Double sided tape - doesn't sound very permanent! U replacing that too?
Old 09-10-2013   #73
deeyup has donated!
Push it Champion
You'd probably be okay not putting more loctite on, and I would definitely put new sticky pads on the front. The old ones were ruined taking them off.
Old 09-10-2013   #74
Netherlands
THX very much.
There are Pretenders among us.....
Geniuses with the ability to become anyone they want to be.
FIAT Panda Lounge 110 Sporting.
The Pretender is offline Reply With Quote Quote
Old 12-10-2013   #75
How does it look?
Thread Tools
(S) Roof rails on hi-roof DoblÚ Bidello Doblo 21 04-12-2015 01:09
(G) Removing Qubo roof rails clockworks Qubo 23 21-11-2014 22:29
(G) Fiat Croma roof bars (without roof rails) uksdsgl Croma 6 15-06-2011 10:20
(S) Roof Rails with Skydome roof ivantate Idea 0 18-10-2010 15:14
