So you're saying that winter tyres are only really good for one winter and after that they won't be as soft?
Make sure these are fresh and not last years stock. In that case ask for a big discount. The stamp on the inside means they are produced in week 33 2013 (being the week ending August 16). Rubber smell overwhelming!
That sounds like he's saying winter tyres need to be new.
The 4x4 Pandas are supplied with winter tyres as standard, not all season.
They are called 'cross contact winter'
click
The reviews are very good. I don't see the point of changing them for a different brand, unless the originals are worn. If anything, a set of summer tyres for the warmer months would be most beneficial.
Hi Most Easterly Pandas, I was questioning our Norwegian correspondent's comment...
Fair point, always best to get the fresh version of anything, but last years stock isn't going to make much of a difference in the UK if its been stored correctly.
These volatile molecules are in essence solvents or softeners. The technique of using "softeners" also applies to many kinds of "soft" plastics.
The softeners slowly evaporate / leach into other solvents like water etc in case the softened compound remains immersed for a long time.
This leaching thing can be a problem as the leaching organic molecules can contaminate the contents of a container / hose in applications where any form of organic contamination might be an issue.
Very interesting, thank you. So presumably that does mean that it's worth checking when your winter tyres were produced?
Whenever I've used mytyres they've come from Germany.Get the tyres through MyTyres as they come from Poland and always seem brand new manufacture.... guess they sell shed loads of them. Also their deals are good for steel wheel + tyre combo, but be careful if for the new 4x4 as they sometimes set up a 14" not 15" wheel
