Thread Tools
Old 25-11-2012   #1
Unhappy Leaking door seals
Well I've just noticed the driver side door seal has started leaking half way between the A and B pillar. Nothing major, just a few drips but it's managed to pool a bit in the door handle.
Just wondering if anyone else has had this problem and is it potentially something I could sort myself? I'm thinking as a worst case it'll need a new door seal but the car's only 6 months old...any ideas what can cause this??
Thanks in advance.
millns84 is offline Reply With Quote Quote
Old 25-11-2012   #2
Forum Moderator
T14086's Avatar
T14086 has donated!
Re: Leaking door seals
Are you sure it's not just droplets remaining after the door has been closed?
Old 26-11-2012   #3
Quote Originally Posted by T14086 View Post
Yes, positive. I've got into the car through the passenger side to get something out of the glove box and that's when I've noticed. It's also collected a bit of water in the door handle, say 1-2mm so definitely dripping continuously.
I can't see anything wrong with the seal either, it seems to sit in exactly the right place, and isn't deformed or damaged in any way...
Old 26-11-2012   #4
Forum Moderator
T14086's Avatar
T14086 has donated!
Next step would be to get door adjusted if seals are all ok.
Thanks millns84 thanked for this post
Thread Tools
(G) Door seals nebrog23 Uno 0 05-10-2012 22:39
(G) where to buy door seals CFREITAS Bravo / Brava 3 13-06-2011 17:05
(G) Door seals scottishpunto Punto (Mk2/2b) 4 15-12-2010 22:24
(G) door rubbers and seals muriloalvares Panda (Classic) 2 11-05-2009 16:14
(T) Door +sunroof seals. westie Stilo 3 10-05-2004 01:52
