Hi all,
I've got a little problem with my TA, the external window beading on the driver's door has become distorted in the top left corner, sounds very similar (if not the same) as that experienced by pilgrim42 under the thread "Boot Mechanism". Is this happening to anyone else's Panda? And is it an item which will be repaired under warranty?
I'm also having the same issues as Super Uwe, RE the internal door seals sticking to the doors after a period of inactivity. It took some pulling to get the door opened the other day, I was feared it would pull the seal from it's seating! It's as if the rubber hasn't cured properly before being fitted, and is trying to bond with the door frame. Has anyone else experienced this, and is it normal?
And one last thing, I am sorry about this... I noticed this morning, after much heavy rain last night, that on opening the boot of the car I could hear alot of water running from inside the the boot lid itself. Again, is this normal? I'm concerned about water lying in there and doing what moisture and mild steel does at it's worst!!
It all may sound a bit petty but this is the first brand new car I've ever owned and don't want it getting damaged through not knowing what is normal (or not). I've never come across any of the above issues before in other cars I've owned, which is reasoning for my concern.
Many thanks in advance...
