im Axle Specialists
Comment
Guide Tools Search this Guide
<!-- google_ad_section_start -->Fiat Panda '04 power steering wheel problem<!-- google_ad_section_end -->
Can I ask for help please with Fiat Panda
Published by Sile ni eochaidh
4 Weeks Ago
Difficulty Level: 1
User Rated:
Difficulty Level: 1
My power steering wheel makes a buzzing sound when i run the wheel when it's stationary, I don't hear it when I'm driving on the road but I do hear it when I'm driving up my driveway. Has anyone got any ideal what could be causing it? would really appreciate anyone that can help, thank you
Old 4 Weeks Ago   #1
varesecrazy has donated!
Re: Fiat Panda '04 power steering wheel problem
No warning lights..??
It is the steering column that is electrically assisted..
Has it had any work done on it lately?
Old 4 Weeks Ago   #2
Ireland
No Light coming on, or no work done on it, battery changed late last year.
Sile ni eochaidh is offline Reply With Quote Quote
Old 4 Weeks Ago   #3
rmjbn1 has donated!
Hi @Sile ni eochaidh
You might get more replies if you re-post your question in the correct section for the Panda here
Just to check: does the steering feel any different? Does it get heavier? Or is it just the noise that's troubling you?
Apart from the battery, other things that can cause problems for the electric power steering are:
  • earth cable - remove the battery and tray, clean the two earth cable connections on the car body and the engine block. Or replace with a new cable.
  • alternator - test if your alternator is charging your battery correctly.
  • battery draining - check for other electrical faults that could be causing a parasitic drain on your battery.
If you don't feel confident about doing these steps yourself, then a motor electrician (or any decent independent garage) can do this for you.
If all else fails, there is a specialist in the UK, who might be able to offer advice: Western Power Steering 00 44 1179 602906
Good luck
rmjbn1 is offline Reply With Quote Quote
Comment
Search this Guide:
Fiat Panda Power Steering itsamugsgame Lets Talk FIAT 4 31-05-2017 13:01
(T) Panda 1.2 SportSound (2004) - Power Steering Problem (Very light!) KumaPanda Panda 15 09-05-2017 12:07
Punto (Mk2/2b) The notorious power steering problem of Fiat Punto Stephen505 Newbie Central 13 04-02-2014 06:45
Does a Fiat Panda Selecta 1993 have power steering???? nothills Newbie Central 3 13-06-2010 14:31
(G) Fiat Punto s60: Power Steering Problem DjStunt Punto (Mk2/2b) 8 16-11-2007 21:23
