Comment
Guide Tools Search this Guide
<!-- google_ad_section_start -->Panda 100HP Rear Seat Removal<!-- google_ad_section_end -->
This is probably the same for other Panda Models
Published by IanV
15-09-2018
Difficulty Level: 1
User Rated:Unrated
To remove the Seat Back you will need a 16mm ratchet & socket.
And a 6mm Allen Key.
There are 2 bolts on the Left and Right side.
And one Allen bold in the center that retains a keep plate (this slides out once the Allen bolt is removed).
The seat backs can now be remove (they are surprisingly heavy) but they do separate in the middle (a shaft connects them together)
The Seat Bench requires just the 16mm ratchet & socket.
Take the boot mat out.
2 bolts forward of the bench and 2 bolts in the boot and 1 bolt at the center Seat Back Support.
And the bench is out, it is very simple and probably doesn't merit a guide.
All you will find under the bench seat is the access panel for the electric fuel pump.
Likes Sheddi liked this post
Old 15-09-2018   #1
Re: Panda 100HP Rear Seat Removal
With Pictures
ID:	194175   Click image for larger version
IanV is offline Reply With Quote Quote
Comment
Search this Guide:
(G) Panda 100hp rear seat removal buckden Panda 3 10-08-2017 16:02
(T) Rear seat removal HUGHI Punto (Mk1) 1 22-09-2013 13:23
(T) Removal of Rear Seat arachnic Ulysse 1 30-09-2011 00:37
(G) Rear Seat Removal carroll Panda 2 25-03-2007 11:38
(G) rear seat removal? wanna be faster Cinquecento / Seicento 9 27-10-2004 16:23
