Comment
Guide Tools Search this Guide
<!-- google_ad_section_start -->Panda REAR Suspension replacement<!-- google_ad_section_end -->
checking integrity of rear spring cups
Published by varesecrazy
15-10-2016
Difficulty Level: 2
User Rated:Unrated
Damper replacement
with the rear beam and wheels at a LOW position , access to the Dampers upper retaining bolts - 15MM HEX is now reasonable.
I found withdrawing the damper downwards and out was the simplest, , I gave the mounting points a quick wipe over with a cloth to make sure there was nothing wrong , or in the way for reassembly,
I then fed the new damper UP into position, and refitted the TOP bolt,
I then fitted the 2 x rear springs into the cups,
and used the trolley jack to raise the rear beam back up to the level for the dampers lower eyes to be back in line - then refit the bolts
once all of the rear suspension components are back in place ,
I used the trolley jack to fully RAISE the rear of the car,
roving my additional safety supports,
then the axle stands
once the underside area was clear - I then carefully lowered the Panda back to the ground ,
and finally torqued-up the 4 x mounting bolts.
Thanks RayovacWorkhorse, CatLeChat, Kronkron, rmjbn1 thanked for this post
Dislikes robbiechad disliked this post
Contents
<<  <    (Page 4 of 4)    > >>
Old 01-03-2020   #1
varesecrazy has donated!
Re: Panda REAR Suspension replacement
Glad this guide is still proving useful.
The car was sold at 15 years old..still good
There are plenty of threads in the panda (and 500) sections
Discussing products to neutralise the rust..and coat in a longlasting finish
As proven with mine..
KEEP IT MUD FREE
and the drain holes clear
Charlie
Old 25-03-2020   #2
rmjbn1 has donated!
Ireland
Thanks again for this guide Charlie, it was a great help
I'm amazed how easy it is to get good access to clean the axle, springs and shocks. Two bolts, the axle drops down and the springs fall out! Winner!
Strangely, the lower shocker bolts on my 2004 1.2 are 19mm hex head, not 18mm
I found a breaker bar to get them started then a drill with a socket attachment to run the bolts out and back in made it a very quick job - they are quite long threads.
rmjbn1 is offline Reply With Quote Quote
Old 25-03-2020   #3
Quote Originally Posted by rmjbn1 View Post
Strangely, the lower shocker bolts on my 2004 1.2 are 19mm hex head, not 18mm.
You are very welcome
It was a quick job one autumnal evening.. but Im now in the habit of taking pics when I do a job..
So I can build a thread later
Might be happening again sometime soon..
Different Head size generally means different thread pitch.. weird
Old 25-03-2020   #4
chris3234 has donated!
Quote Originally Posted by varesecrazy View Post
The bolts on my 500 axle were 19 mm head
I know because I used one of my alloy wheel socket's to remove/reinsert them
chris3234 is offline Reply With Quote Quote
Old 25-03-2020   #5
Quote Originally Posted by chris3234 View Post
Its possible it was a Typo.. ?
But my grande strut bolts..and nuts.. were 18mm... so cannot rule it out
Old 26-03-2020   #6
In likely if you look at your pictures you can read the 18mm on the side of the socket you used
Old 15-09-2021   #7
Yolanda has donated!
I'm led to believe your not supposed to Jack the rear of the car up on the axle beam as it will bend it resulting in tracking issues.
All help Gratefully received.
2004 Panda 1.2 Dynamic.
2013 Mercedes SL350 Weekend Car.
Yolanda is offline Reply With Quote Quote
Comment
Search this Guide:
(T) Rear suspension buffer replacement ponder Punto (Mk2/2b) 3 25-11-2014 12:25
(T) Fiat Multipla rear suspension replacement - help! md123 Other Fiats 1 22-02-2013 07:49
(T) Fiat Multipla rear suspension replacement - help! md123 Multipla 2 21-02-2013 15:13
(T) Rear Suspension Arm Replacement Fivestiles Punto (Mk1) 9 21-03-2011 10:20
Rear suspension replacement Ed FIAT Boo Archives 3 16-05-2008 16:33
