FIAT Auto Specialist Team
Comment
Guide Tools
<!-- google_ad_section_start -->Panda 8 Valve cambelt change<!-- google_ad_section_end -->
Published by varesecrazy
26-03-2016
Difficulty Level: 3
User Rated:
Difficulty Level: 4
engine mount and top plastic shroud
this is more awkward than technical.
Name:	panda maint dec 13 088.jpg
ID:	166126Click image for larger version
Name:	panda maint dec 13 087.jpg
place a trolley jack under engine sump pan,
using a plate of solid wood as a load spreader
Name:	panda maint dec 13 085.jpg
take the weight of the engine, you do NOT need to jack up the car..it can remain on it's wheels.
however for access / better pics I've removed the RHS front wheel, this may be the better option.
Contents
<< <    Next Page: Engine mount (Page 1 of 4)    >  >>
Old 27-03-2016   #1
varesecrazy has donated!
Re: Panda 8 Valve cambelt change
tools used; 10 and 13 mm socket, or spanner -10 mm socket is better for belt casing
15 mm Socket / Spanner for engine mounts
3/8 flexy ratchet, awkward access to wind the engine mount bolts
pliers to pre-load the belt tensioner
Name:	panda maint dec 13 079.jpg
parts removed,
belt casing upper and lower,
engine mount ( in 2 parts / sections)
Name:	panda maint dec 13 083.jpg
Old 01-04-2016   #2
testacorsa has donated!
Denmark
Thanks man. Looks easier than expected, and I expected pretty easy I'm surprised that the cam doesn't need to be locked - bonus!
testacorsa is offline Reply With Quote Quote
Comment
Guide Tools
(T) Cambelt change on ultra low mileage Panda MarkyTDI Panda 27 08-04-2014 10:01
A for Alfa in Aylesbury. Panda 100HP Cambelt change BambooShoot Garages 0 12-08-2012 15:32
(T) panda 4x4 cambelt change hollister Panda 9 08-11-2011 11:09
(T) 2.0 20v cambelt change help and fuel filter change help Wilqaeda Marea 4 13-10-2009 13:20
