Comment
Guide Tools Search this Guide
<!-- google_ad_section_start -->Blaupunkt AUX in,<!-- google_ad_section_end -->
Blaupunkt AUX in,
Published by hambo44
11-04-2015
Difficulty Level: 1
User Rated:
Difficulty Level: 1
Smile Blaupunkt AUX in,
What you will need,
A Aux In kit. I got it on Ebay, you can get one that will fit straight in with a little yellow block on the end. This saves having to cut the blue plug up.
A wire coat hanger (Cut the two corners off leaving prongs of equal length).
Some flathead screwdrivers and other leavers.
A sharp knife.
And some electrical contact cleaner (not necessary but good to clean up all the connectors)
Contents
<< <    Next Page: Removal, (Page 1 of 4)    >  >>
Old 16-04-2015   #1
Re: Blaupunkt AUX in,
Really useful! Thank you
Professor Yaffle is offline Reply With Quote Quote
Old 16-04-2015   #2
Its good to know that it is of use to someone!
hambo44 is offline Reply With Quote Quote
Old 12-12-2015   #3
Panda Fanatic
SB1500's Avatar
SB1500 has donated!
http://www.ebay.co.uk/itm/201386524123
Would the cable from this work? :-)
2017 Fiat Panda Easy 1.2 - 31,000 miles
2005 Fiat Panda Dynamic 1.2 - 153,700
SB1500 is offline Reply With Quote Quote
Old 12-12-2015   #4
Yea that looks about right! I'm 90 percent sure that you won't even need too butcher that yellow plug. Should plug straight into the back of the radio. But if it doesn't you can always adapt it as above.
Old 05-03-2016   #5
Nothing happens when I pressed CD twice, is there any other way to get Aux as a source?
Littlenoddycar is offline Reply With Quote Quote
Old 05-03-2016   #6
Quote Originally Posted by Littlenoddycar View Post
Hi mate what car is it? Does the radio say 'MP3' on it?
Old 22-04-2016   #7
hi, do you need to have done the mod in order for aux to be the source once CD has been pressed twice, as when i press cd twice nothing happens. i havent done the mod yet just interested to know if it only works, once the mod has been done. cheers
Pinnch is offline Reply With Quote Quote
Old 22-04-2016   #8
Hi i was wondering if you know how to get radio codes for fiat pandas for free?
Robert1990 is offline Reply With Quote Quote
Old 22-04-2016   #9
Quote Originally Posted by Pinnch View Post
Old 22-04-2016   #10
Quote Originally Posted by hambo44 View Post
yes it does
Old 16-12-2016   #11
mikelawrencenz has donated!
Smile Re: Blaupunkt AUX in,
Thanks alot, great little guide, took 15mins (most of that was threading the cable to the passenger foot well).
I ended up placing a brightly coloured screwdriver up in behind dash so I could see in the back left corner of the head-unit hole. Gave me something to aim the cable at.
Works a treat
mikelawrencenz is offline Reply With Quote Quote
Old 22-01-2018   #12
silvermunro has donated!
anyone know how to select aux if there is no CD button. U only have source, so pressing it twice jumps it from CD to radio & back. It had the aux fitting in the back, so fitted the aux cable, just can't work out how to select it
silvermunro is offline Reply With Quote Quote
Old 17-05-2018   #13
Did you ever find a way to select AUX? can't find it anywhere online
yazaln is offline Reply With Quote Quote
Comment
Search this Guide:
Blaupunkt aux cable kritip Auction Watch 0 20-02-2013 16:16
(G) Aux in on Blaupunkt HU with Blue&me? arsenalfc Grande Punto 7 12-06-2011 10:09
(T) Blaupunkt Aux in Punto guyjos Punto (Mk2/2b) 1 30-12-2010 21:36
(T) Aux input on original grande punto blaupunkt hu Robert1031 Grande Punto 4 30-10-2009 23:17
Which Aux cable for Punto factory Blaupunkt? tyeness I.C.E 0 26-09-2007 12:31
