Today I have a throttle problem which has started. The pedal is fine till the last inch or so of travel, it then gets stiff and notchy. I have lubricated the pedal and around the base of the cable, to no effect. Both ends of the cable seem fine, whats happening? The carb end is working perfectly, it sounds from the noise its making to be coming from the pedal end.
