I've been having this problem with the Injection Panda for a while now. Mainly in 2nd and 3rd gear when accelerating the power keeps going for very short bursts. (The problem seems to be slightly reduced if you accelerate hard). It only happens once the engine is fully warmed up and is worse after doing a prelonged period at higher speeds. I have a feeling it is also worse pulling up-hill. Tonight I was almost home and it was doing it badly and then the throttle stuck completely open so I had to turn the engine off and park up and release the stuck valve.
I've given the throttle body a a good squirt with injection cleaner, run Redex through the system and changed the fuel filter. No joy so far. Any thoughts? Does the throttle sticking open suggest what the problem might be or is it unrelated? A year or so ago I had the lambda sensor replaced and the garage told me then that the throttle body was quite warn. Is this likely to be the cause?
Any suggestions gratefully received before I bite the bullet and take it in. I wish this car was as reliable as the 20 year old!
