toecutter
1) Fresh brake pads, new HB cable- stops nice! Old shoes like polished glass.
2) All lights/indicators working- bad earth wire connection
3) Horn found, removed. Violet wire had been cut. Spliced. Horn works...continuously! Violet is live, always, even with key removed. Gray/black is the earth, that should have contact broken by the horn button. Horn button removed, therefore no contact between column and springs. What to look for now? It seems that the circuit must be completed by a connection in the column, or someone has tapped into the earth somewhere along its route. Ideas?
Justin
Justin
