Thread Tools
Old 06-02-2007   #1
Converting to electronic ignition
I have read posts about this, but there are still a few questions I would like to ask.
Has anyone done this conversion, any difference in running?
Will I need to rewire anything or can I just take the wires off the existing coil and put them on the electric one?
Can i use existing spark plugs and leads?
Do the distributors wear out, I've found one on an Uno 45 with 60k on the clock.
I want to do this conversion because I'm fed up with the car loosing power, usually on a damp day, and also because I think the cam is badly worn on the dizzy.
Will
wilharper2000 is offline Reply With Quote Quote
Old 07-02-2007   #2
Re: Converting to electronic ignition
I would try the Luminition supplied Newtronic kit. I've never used their electronic ignition conversion kits, but I have used Luminition programmable ECU's in BMW's and they make some very good stuff.
They list a kit for the Panda and the Uno...
FIAT
Uno 83-91 DU 525345A T101A
Panda 79-85 DU 525243A T101B
Full details can be found here along with other contact info etc...
http://www.lumenition.com/newtronic/system/index.html
The co-driver is offline Reply With Quote Quote
Thread Tools
(T) Electronic Ignition Conversion 852421 X1/9 5 01-04-2008 17:03
(T) no spark in electronic ignition samantha Bravo / Brava 2 26-02-2006 15:51
(G) Electronic Ignition Thingy Sprox Panda (Classic) 39 22-02-2006 11:46
(G) uno mk1 ignition switch wiring coolhand_mike Uno 0 07-10-2004 00:58
(T) Ignition cuts out :-( quater Punto (Mk2/2b) 2 10-05-2004 22:59
