General brake shoe thickness Panda cl1000
toecutter
merthyr turdfull, United Kingdom.
Read up on the brake shoe debate a couple of pages back. Fitted new handbrake cable- lots of slack- suspicious. Removed drums and found shoes to be from 1mm to 3 mm thick. Quoted from local motor factor £12 for replacement shoes. Correct me if I'm wrong, but the handbrake should engage a lot sooner if the shoes are new, good and thick. I'm thinking that the handbrake doesn't engage until late, even with most of the adjustment taken up BECAUSE the shoes are thin. Correct, or have I missed something?
It's possible you've missed the "concept" of self adjusting shoes.
They are supposed to self adjust - it's a moot point if they do, or not.
Either way, 1 to 3mm is effectively worn out.
4mm atleast...and then you know they wear on the "upper" side where they're pushed by the cylinder;).
Passion has neither brands nor models!
La passione non ha nè marche nè modelli!
(Quite happy dark met. blue Panda driver!)
You can usually tell that the drums are worn when you try to get them off. You usually wreck the shoes trying :(
Cause: a "lip" on the inside just inside the rim which catches the shoes and pulls them off!
Steve the geriatric Panda and Beagle freak
G781 TUT: White Panda 1000CL - 31-08-1989 to 09-03-2004 (may she rest in pieces :()
J154 FMX: Gorgeous little red Panda 750L in good condition - screaming for me to rescue her :)
