General Oh F$%K- pedal box
toecutter
merthyr turdfull, United Kingdom.
Discovered reason for low clutch. Cable is fine. However, the clutch, gas pedal and brake pedal/MC are all bolted to a plate that bolts from the inside of the car, to the shell/body. It has split just below the clutch pedal gusset. Is there any easy fix? Braze? bolt a plate over the split, new pedal plate? Ideas? I'm not looking forward to removing everything to replace a plate that is probably not available, or only from Fiat for £100.
Justin
I've not had to repair/replace one of these.
I'd consider looking at a scrap/breakers yard for a secondhand part.
BTW How much were you paid to take this Panda away - it seems to be in quite a stateB)
That's probably why it cost you £21 to buy it :)
Steve the geriatric Panda and Beagle freak
G781 TUT: White Panda 1000CL - 31-08-1989 to 09-03-2004 (may she rest in pieces :()
J154 FMX: Gorgeous little red Panda 750L in good condition - screaming for me to rescue her :)
