toecutter
Discovered reason for low clutch. Cable is fine. However, the clutch, gas pedal and brake pedal/MC are all bolted to a plate that bolts from the inside of the car, to the shell/body. It has split just below the clutch pedal gusset. Is there any easy fix? Braze? bolt a plate over the split, new pedal plate? Ideas? I'm not looking forward to removing everything to replace a plate that is probably not available, or only from Fiat for £100.
Justin
Justin
