My engine keeps stalling at lights and sometimes between gear changes if im not fast enough. What could be causing this? Its not all the time though, the engine is strange, fluctuating in revs. When its idling ok, it will try and stall when i open up the throttle. I have recently changed the spark plug leads as they were the original ones on the car (21 years old, not bad going i supose), the carb is ok i think. Ive checked the jets were'nt blocked and blown throught them to make sure as that usually sorts it out. But not this time. I am left with only two idea's now, the spark plugs are now a little crappy due to the crap leads it had on till not long ago, or the dizzy needs to be looked at. Points might need a check.
Are there any other options, or have i pretty much covered all of it?
Si
Si
