i have just been told that the engnie mount has broken and in turn broke the drive shaft? in my old panda (now my brothers) what is likley to cause this and how hard is it to fix
Depends on which mount has broken. If it's a FIRE engine it may be the alloy one on the left as you look under the bonnet (cambelt end of the engine). If this snapped the engine would drop on that side maybe enough for the drive shaft to pop out of the diff (very bad if you're moving when it happens). It's not the end of the world. The mount is easy to replace, the drive shaft rather more difficult. Not a job for a beginner...
